25-01-2011, 08:44 AM #1
Using the fridge motor to trigger another electrical device
I would like to use an extractor fan to create or augment a cool updraft behind a fridge. The fridge is a Smeg SR-640. I would like the fridge motor to trigger the fan, so they both run (i.e. turn on and off) at the same time. I'm told the fan should be connected to the compressor, but I'm unsure how the connection should be made, or if there's a better way. Advice would be welcome, please.
25-01-2011, 04:37 PM #2
Re: Using the fridge motor to trigger another electrical device
On the electrical terminal block where the three core cable (live, neutral and earth) comes into the appliance, look for a four core cable/flex. These four cores (live, neutral, earth and common, are the electrical supply feeding up to both the thermostat and other components within the fridge.
Basically the live feed goes to the thermostatelectrical switch and then returns to the common terminal on the compressor overload/cutout device. This common terminal is only live when the thermostat switch is in a closed circuit (on) posistion. So just add the live wire of the fan into this circuit in a safe manner and both the compressor and fan will run together and stop running together.
25-01-2011, 04:47 PM #3
You could just switch the fan via a thermostat and let it cycle independently of the compressor.At a set temperature
If the manufacturer thought the condenser required a fan they would have fit one .I think
But then again i don't do domestics
Warm Fridge
By leongf in forum Technical SpeculationsReplies: 8Last Post: 16-04-2010, 08:42 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
part p
By eggs in forum ElectricalReplies: 25Last Post: 15-11-2007, 08:55 PM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
