23-08-2005, 05:29 AM #1
upside down fridge/freezer not cooling properly
I have recently bought a second hand 420 litre frost free westinghouse with the freezer on the bottom. It is about 3 - 4 years old.
Its been plugged in for about 3 days now, and the freezer section is not that cold. I have both the fridge and freezer thermostats on coldest, and neither section feels as cold as it should be. The fan has been running continuosly - it seems as if the fridge isn't cooling for whatever reason so the thermostat tells the compressor to keep running. The fan will turn off if I twist the thermostat around to warm.
Any ideas greatly appreciated.
23-08-2005, 11:54 AM #2
Re: upside down fridge/freezer not cooling properly
Take out gas weigh and recharge may resolve problem.
29-09-2005, 03:11 PM #3
question? what is the refrigerant? what is the suction pressure? what is the air td over the freezer evap? if its a fan assisted condensor, what is the ait td over this?
29-09-2005, 08:02 PM #4
Hi Barney01,
Are there two compressors?
If it runs on 134, It is in many cases, a blocked cap tube.
Chemi
29-09-2005, 09:54 PM #5
Erm guys,
I think barney01 came here posted that and aint been back since which was a month ago.
and go get a cuppa
07-10-2005, 08:20 AM #6
should be a single comp job running on 134a
i'd say the defrost element has blown causing freezer coil to ice up as dtt still has circuit to run evap fan, if coil wasnt cold fan shouldnt run, either that or time clocks packed it in and its stuck on fridge."Old fridgies never die, they just run out of gas!"
Heating / Cooling Control
By walden in forum ElectricalReplies: 11Last Post: 16-04-2006, 01:20 PM -
cooling tower without fillings
By Lc_shi in forum FundamentalsReplies: 3Last Post: 27-12-2005, 12:55 AM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Regulation of cooling capacity
By npaisnel in forum DomesticReplies: 13Last Post: 08-02-2002, 11:22 PM
