    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    Prestcold K100 compressor data
    Has anyone out there got performance and physical data for an old Prescold K100 ... series single phase .
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    3,853
    Re: Prestcold K100 compressor data
    I've got info on the PK10X/0011, 0014, and 0017 models, which is the slightly newer ester oil version.....
    Jon
    nevgee's Avatar
    May 2006
    Yorkshire
    72
    417
    System I'm looking at has K100 I think ... It's in such a state it's difficult to identify anything .
    I'm guessing it will have a nominal duty 1700 - 2000 W Evap at 0C; 40/ 45C cond.
    The tx valve has R12 label. But then that's no indication not having a history of this system.
    I was going to get a reman comp but think it might be just as cost effective to rip out the old unit and fit new con Unit. So being able to cross check the duty would be helpful.
    Feb 2009
    telford
    2,090
    33
    you will struggle to find a more reliable compressor,i have seen so many old ones still going strong[that is when they are installed correctly.
    nevgee's Avatar
    May 2006
    Yorkshire
    72
    417
    Quote Originally Posted by cadwaladr View Post
    You're probably right , this machine must have been running for +20 yrs. But the customer is looking at perceived value, recon compressor or total new cond unit , iether one at the same price ....
  1. Prestcold compressor spares
    By Pengu in forum Commercial
    Last Post: 08-05-2010, 03:03 PM
  2. Prestcold Semi-hermetic
    By Iceberg1138 in forum Tools and Calculators
    Last Post: 19-02-2010, 02:26 AM
  3. Replies: 0
    Last Post: 09-08-2009, 03:30 AM
  4. Relay for Prestcold K202D
    By colingwatkins in forum Electrical
    Last Post: 25-06-2009, 10:19 AM
  5. Prestcold K100 & K150
    By colicool in forum Technical Discussions
    Last Post: 21-07-2008, 09:30 AM
