Thread: Frost free fridge/freezer
21-08-2005, 09:50 PM #1
Hi guys,
Have a Liebherr No-frost fridge/freezer fridge 5c, freezer only -10c, display bleeping, R600a single pot has a 3 way valve.
Suction pipe next to compressor frosted up, enough gas in system.
Be greatfull for any help.
21-08-2005, 10:10 PM #2
Re: Frost free fridge/freezer
Evap iced up?
Evap fan not running?
Not condensing enough?
Nice fridges those.IF AT FIRST YOU DON`T SUCCEED.
and go get a cuppa
21-08-2005, 10:14 PM #3
Thanks is it no a board problem
22-08-2005, 07:07 PM #4
Their UK distributor is Coolectric, they should be able to supply a service manual or maybe have an idea of what the problem is:
<http://en.liebherrinfo.nl/service.php>
It might have extra controls to enable it to work properly in lower temperatures (-5c), perhaps the FF is operating as if the ambient is much lower than it is.
In which case check for an extra thermostat on the outside of the cabinet somewhere and how it affects the FF.
cheers,
Pete.
22-08-2005, 07:44 PM #5
Make sure the fan is going the right way, and the blade is on the right way.IF AT FIRST YOU DON`T SUCCEED.
and go get a cuppa
22-08-2005, 11:52 PM #6
Thanks guys you have been very helpfull you Know what these frost free are like a right ******* pain
23-08-2005, 12:07 AM #7
Chillin Out,
Not overcharge frosted on visit.
Thanks anyway.
23-08-2005, 01:33 AM #8
I think your evaporator coil is iced up , or evap fan not working
Check defrost cycle
LIEBHERR Frost Free fridge
By Lucas in forum DomesticReplies: 9Last Post: 30-09-2008, 09:07 PM -
Leaking frost free fridge-freezer
By diment01 in forum DomesticReplies: 5Last Post: 22-06-2006, 11:49 PM -
By ice-cold in forum CommercialReplies: 10Last Post: 26-05-2005, 07:55 PM -
By aircon in forum DomesticReplies: 0Last Post: 21-05-2005, 09:44 PM -
Kelvinator Frost Free PCB
By Lucas in forum DomesticReplies: 5Last Post: 28-01-2004, 09:12 AM
