Results 1 to 11 of 11
    b.tikekar18's Avatar
    b.tikekar18 Guest
    Blast freezing of meat
    Dear Sir
    Iwant to know the detail procedure of blast freezing from fresh cut meat till putting in the blast freezer. Specialy the precautions and or treatment if any to be provided to the meat before putting in the freezer. the maximum time allowed btween cutting and keeping in freeze.
    Thanks and Regards.
    Dear Sir,
    I want to know complete blast freezing procedure of meat from fresh meat ( just obtained after slaughting ) till it is kept in Blast Freezer. Specially I want to know the precautions to be taken and or any treatment to be given before putting in the freezer. If it can be washed with water before freezing. Please reply.
    Thanks and regards
    Just after slaughting
    After slaughting and cutting properly.
    Thanks mbc
    Hi, TESLA
    I want to freeze EMU meat (Red Meat )
    Oct 2008
    mallorca, spain,
    75
    768
    Re: Blast Freezing of Meat
    hi , but why post the same thread twice?
    Aug 2007
    Sydney
    52
    1,083
    23
    Hi b.tikekar18
    There are more than one ways of skinning a cat so you could expect a variety of answers. Depending on the type of meat and cooling/freezing process involved. eg fish are washed when skinned and filleted, put in a box with a plastic cover then blast frozen, then put into holding freezer. Where red meat or chicken may be processed a little different. Some old timers would say that red meat should hang for a few days to let rigamotus set in for a more tender cut. The slaughtering process will also have an effect and how soon it is gutted or offal removed. Whilst frozen a vapor proof seal on the product helps prevent freezer burn. Also while being stored a more stable temp with less deviation will decrease deterioration of product over time. ? have you ever bought ice cream that was half ice and half cream - this product has not had a stable temp or been stored at low enough temp. If you have a certain type of meat in mind let us know. Hence defrost parameters are important too.
    Sep 2009
    Iran
    66
    672
    1
    Dear tikekar 18
    Each packing has oven line so each one has oven precautions how to put in blast Freezer.
    In your design you should look for these items
    1-Air flow ( capacity – direction – how it goes through goods) is very important
    2-Temperature of room (as much as you go to low temperature it give you good condition of goods )
    3-In your design you should put your defrost time in loading and unloading time of room.
    4-Insulation of room and door plus emergency equipment (lights and shot down the system) and choosing right lighting is very important.
    5-Mode of loading goods in room (Box pallets and Boxes and covering of goods is important )
    Dec 2010
    devon
    837
    ask a butcher?
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    Oct 2007
    manchester
    5,639
    45
    fred west buried his meat to preserve it!
    Auckland
    74
    3,357
    37
    Re: Blast freezing of meat
    where do you want to start?. At the slaughter stage, process stage, cutting floor stage, personal and area hygeine stage, air quality stage. Plant hygeine stage
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, b.tikekar18
    Quote Originally Posted by b.tikekar18 View Post
    Dear Sir
    Thanks and Regards.
    this should be more then enough for start enjoy in reading
    http://www.fao.org/docrep/004/t0098e/t0098e00.HTM
    Best regards, Josip
    Dec 2008
    Portugal
    48
    1,020
    Good book Josip,
    I'll read it more carefully as soon I have time.
    Jan 2006
    Croatia
    68
    2,261
    31
    Quote Originally Posted by Sandro Baptista View Post
    Good book Josip,
    ..... and only 20 years old
    Best regards, Josip
  1. Replies: 9
    Last Post: 19-06-2010, 04:48 AM
  2. Blast Freezer Within Freezer
    By rickmor in forum Technical Discussions
    Last Post: 18-06-2009, 03:37 AM
  3. Blast Freezing Q's
    By Mutaz Suhail in forum Industrial
    Last Post: 03-06-2009, 08:57 PM
  4. Blast Freezing
    By Mutaz Suhail in forum Fundamentals
    Last Post: 25-03-2007, 01:08 PM
