20-01-2011, 10:23 PM #1
bosch KAN58A40GB/07 freezer not freezing
this american style side by side is not getting cold enough in the freezer it sayed -18 on the display but its more like 0 or +1 the condenser fan is working and i had the back inside cover off to expose the evaporator it had a block of ice on top of it so i let it defrost for a day or 2 , where do i start with diagnostics is there a bosch diagnostic routine ?? thanks
25-01-2011, 12:07 AM #2
Re: bosch KAN58A40GB/07 freezer not freezing
i dont usually do domestic but block of ice on the evap coil sounds like a defrost problem (check heaters/defrost settings). Is the temp sensor/ probe in the evap coil or surrounded by ice? if so it would explain why your getting a reading of -18 on the display. Another possibility is that temp sensor/probe is out of calibration causing freezer to run all day long causing evap coil to ice up, is evap fan running?
26-01-2011, 03:30 PM #3
no evap fan running just pulled it out and i cant get a reading off it with my mutimeter , its all over the place on the scale goes to o/l and back to 58 ohms and back to o/l constantly thats with the fan stationary its a 13v dc motor so i presume same rules apply when checking for earth leakage and comtinuity through the control wires
candy frost free freezer freezing up
By elmostreet33 in forum DomesticReplies: 1Last Post: 08-01-2011, 10:28 PM -
Help! Top of Bosch Freezer not freezing food
By herbertkerry in forum RefrigerantsReplies: 3Last Post: 31-01-2010, 10:07 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
bosch fridge freezer
By geoffishere in forum DomesticReplies: 16Last Post: 05-08-2008, 05:13 PM
