Results 1 to 10 of 10
Thread: Gasket
20-01-2011, 01:13 PM #1
Gasket
Would like to know the gasket material (name) which come along with semi hermetic compressor and which type of gasket good for semi hermetic when overhaul.
My dad brought back few sheets of different brand, different dia. gasket from Malaysia which in very low quality, few months after it all leaks especially discharge area , i'm going to Singapore soon so hope can find the correct material. Someone told me look for asbestos gasket, correct me if he's wrong. Thanks
20-01-2011, 01:48 PM #2
Re: Gasket
Asbestos is dangerous and pollutant. Have you tried with the manufacturer of the compressor?
20-01-2011, 05:07 PM #3
Re: Gasket
When I didn't have the right gasket in the van, I used the kind of gasket used by car mechanics.
I don't know the name but it is thin hard material, soak it in refrigeration oil and it becomes soft and easy to work with.
Mark the shape with a solid piece of aluminium, cut with a sharp knife and you get the gasket you desire.
20-01-2011, 06:37 PM #4
Re: Gasket
20-01-2011, 07:09 PM #5
Re: Gasket
This stuff is made of layers and not easy to work with, but this is my experience and opinion only.
20-01-2011, 07:37 PM #6
Re: Gasket
Klinger is actually one of the suppliers of most compressor manufacturers, but unlikely to supply the raw material in small batches.
20-01-2011, 11:09 PM #7
Re: Gasket
Some Klingersil C-44's are a used in refrigeration.
Had no problem in the Uk getting Klingersil, depending on thinkness normally cut from roll 1metre wide, not cheap though.. Found them good to work with, although there is a bit of skill involved in making good gaskets..
They produce loads of different types for different applications..Last edited by Gingerair; 20-01-2011 at 11:38 PM.
20-01-2011, 11:14 PM #8
20-01-2011, 11:26 PM #9
20-01-2011, 11:36 PM #10
Re: Gasket
As NNN says Klinger supply gasket material to many OEM companies..
From Google, Klinger agents Singapore-
http://www.shipserv.com/search/resul...%5D%5B%5D=2372
Replacing a Liebherr Fridge Gasket Seal
By bazokajoe in forum Trouble ShootingReplies: 1Last Post: 20-11-2010, 11:16 PM -
Bitzer gasket
By Renato RR in forum FundamentalsReplies: 5Last Post: 04-11-2010, 10:08 AM -
universal door gasket
By Andy AC in forum CommercialReplies: 1Last Post: 18-02-2010, 07:24 PM -
Gasket Removal. A Handy Tool!
By Grizzly in forum Tools and CalculatorsReplies: 4Last Post: 03-03-2008, 01:43 AM -
Blown Discharge Gasket
By nh3wil in forum Industrial CompressorsReplies: 5Last Post: 22-08-2006, 04:59 PM
