Thread: Anti-vibration mountings
19-01-2011, 08:19 AM #1
Bitzer recomended:
The compressor can be rigidly mounted, if no danger of breakage due to vibration exists in the associated pipeline system....
Otherwise the compressor must be fixed on anti-vibration mountings.
How do you calculate when anti-vibration mountings need?
Best regards, Aik.Last edited by Aik; 19-01-2011 at 08:21 AM.
In some places will have to think ...
19-01-2011, 08:59 AM #2
Re: Anti-vibration mountings
if you turn up to a breakdown and find elbows fractured/twisted and leaking around compresser after the fact is usually a good indication of said problem.
can also be from too loose mounted compresser too from moving on startup like a scrol.
you can also feel the pipework to see if compresser vibration mountings are needed which i usually find on larger comercial compressers or combination of both this and vibration elimination pipe work."Old fridgies never die, they just run out of gas!"
19-01-2011, 08:04 PM #3
Have a read or download....
http://www.vibrationmounts.com/V100/V100Cat.htmBrian - Newton Abbot, Devon, UK
20-01-2011, 08:00 AM #4
Thanks a lot.
I'm interesting how do you know do you need anti-vibration mountings or not, when planing condencing unit or compressor's mains? Is it only practical experience or have a simple formula?In some places will have to think ...
20-01-2011, 05:16 PM #5
Every manufacturer builds different condensing unit.
Some with Anti-vibration mountings and some without.
Big compressors vibrate less because of the weight.
A good quality flexible pipe connected in the right direction and place, can over come the mounting problem.
You have to check the cause of vibrations.
Some time they indicate a broken valve or piston rod.
Anti Short Cycle
By schow168 in forum Air ConditioningReplies: 5Last Post: 15-04-2010, 12:22 AM -
Tracking down a vibration
By desA in forum FundamentalsReplies: 5Last Post: 19-12-2009, 06:20 PM -
Anti Vibration Pads the answer?
By superswill in forum Technical DiscussionsReplies: 4Last Post: 06-08-2009, 03:50 AM -
Anti vibration compressor mounts
By danshotter in forum Trouble ShootingReplies: 3Last Post: 12-10-2007, 01:33 AM -
Luiquid line vibration and liquid hammer
By Infinity in forum Trouble ShootingReplies: 12Last Post: 09-02-2007, 10:22 PM
