    skoerper's Avatar
    skoerper Guest
    R407A as a substitute to R22 & R404a
    I'm interested in getting some feedback from any one thats worked with R407A either as a replacment to R22 or R404A in med and low temp refigeration equipment or in new equipment?
    Sep 2009
    Iran
    66
    672
    1
    Re: R407A as a substitute to R22 & R404a
    what kind of information you need?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Yes, in Frascold's there are preliminary tests going on. It looks a decent replacement for R404A
    Feb 2008
    Las Vegas, NV
    67
    330
    Quote Originally Posted by skoerper View Post
    Follow this link to Copeland's view/approvals.
    http://www.hvacrinfo.com/Cope_quick_ref.htm
    You should start with their Application Engineering Bulletins and go to Section 26.
    Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
    ireland
    1,450
    41
    We've done one retrofit with it so far, what info do you need?
    Alec
    Dec 2010
    devon
    837
    used it on low temp no problem however on med temp we had real headpressure fluctuations to the point we done two rooms and still had same fault and realy slow temp pull when room pulling about six dc mark .pulled it out and used reclaim 22
  1. R507 instead R404a?
    By Friobernal in forum Refrigerants
    Last Post: 09-04-2011, 12:42 AM
  2. Helpful stuff for r407a users
    By Blueboy in forum Supermarket Refrigeration
    Last Post: 18-09-2010, 05:22 PM
  3. R404a to R407a conversion
    By Silhouette in forum Supermarket Refrigeration
    Last Post: 18-09-2010, 08:13 AM
  4. Max low side pressure in R404A system
    By Wilade in forum Technical Discussions
    Last Post: 25-08-2009, 09:23 PM
  5. R134a or R404a
    By jingua_ph in forum Refrigerants
    Last Post: 27-09-2006, 03:31 PM
