Thread: Refrigeration calculation
19-01-2011, 02:45 AM #1
Can someone help to calculate the size and the volume of an ammonia suction pressure receiver and what size liquid pump should be used for a 90ton chilling room measuring 40ft x 83ft x 11ft.
Also if the capacity of the compressor and the evaporative condenser was given, what would the size and volume of the high pressure liquid pressure vessel and how many tons of liquid ammonia would the high pressure liquid pressure hold at a safe level.
04-02-2011, 11:11 AM #2
Re: Refrigeration calculation
Mate people usually get paid for this information, I suggest you contact a consultant to work it out for you.
...and she said "give it to me you big fridgie"
04-02-2011, 12:08 PM #3
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
what you mean of suction pressure receiver? you mean suction separator vessel?
1- you should calculate your load.
2- you design your system ( Comp. Cond.)
3- calculate how much you need liquid to cool room down then capacity of you NH3 pump.
4- after that you receiver size
your system is too small you go for this type of system. I Think it is better you go to for ferion R -22 or other type or if you want or you have to use NH3,go for NH3 DX system. the cost more more less than pump system in this size.
05-02-2011, 02:47 AM #4
Just exactly are you trying to do? Because the 90 ton figure doesn't match the room size very well.
And like MBC said a 90 ton system is too small to warrant an ammonia system.
22-02-2011, 10:18 PM #5
No big drama bro, I was just trying to open up technical discussion with some smart refrigeration gurus out there.
how can we calculation industrial refrigeration
By lam sanh in forum System OptimizationReplies: 34Last Post: 28-02-2011, 01:31 PM -
Refrigeration calculation help for small (I mean real small)brewery
By Terrazza in forum FundamentalsReplies: 4Last Post: 26-07-2010, 09:08 AM -
Need Help in Refrigeration Calculation
By Jason_09 in forum FundamentalsReplies: 7Last Post: 30-06-2009, 07:10 PM
