Results 1 to 2 of 2
    Jul 2001
    West Lothian, UK
    Scroll Compressor
    I don't work with that many scroll condensing units but recently I took on a site with such a unit with a few problems.
    I seem to recall a discussion with a forgotten party concerning the fact that scroll compressors should not be used on a pump-down set-up.
    Can anyone shed some light on this.
    David
    Jul 2001
    Northern New York
    42
    Post
    Copeland has developed scroll units for commercial refrigeration that may be used with liquid line solenoid valves for pumpdown systems. An improved discharge check valve is incorporated into the compressor. A small amount of high pressure gas blows backward through the scrolls on shutdown, causing reverse rotation briefly. Air conditioning compressors may not be suitable, however, for pumpdown operation. Check with the manufacturer on you particular applications.
  1. About Copeland ZB scroll compressor
    By ernestlin in forum Technical Speculations
    Last Post: 27-08-2009, 08:39 AM
  2. Dual Scroll Compressor
    By ernestlin in forum Technical Discussions
    Last Post: 27-06-2006, 04:14 AM
  3. 60Hz Copeland scroll compressor
    Last Post: 05-06-2006, 09:08 PM
  4. Scroll compressor
    By Abe in forum Technical Speculations
    Last Post: 25-03-2003, 12:47 AM
