Results 1 to 2 of 2
16-01-2011, 10:06 PM #1
Need Help with Beverage Air Freezer EF48-1AS
I need help determine the problem to my freezer. Food got soft and notice the Evaporator coil is all iced up. I have defrosted and clear up all the ice but noticed that the Evaporator fans is not running when I turn the unit back on. Is the fan suppose to run at restart again? Right now.. temperature is at about 20 degree but not freezing. Compressor is about 6 months old...! Any advice...?
21-01-2011, 08:23 PM #2
Re: Need Help with Beverage Air Freezer EF48-1AS
the evap fans should be running if the compressor is running for sure,
sounds like your the owner? call for an engineer and let him sort it? dont try to run your plant without the evap fan or you risk damage.
Maytag Freezer TOO Cold (and fridge also)
By ptb626 in forum DomesticReplies: 1Last Post: 17-08-2010, 01:56 PM -
Chiller/ Freezer Partly Frosting
By Mistral1962 in forum Trouble ShootingReplies: 4Last Post: 02-05-2010, 06:44 AM -
Blast Freezer Within Freezer
By rickmor in forum Technical DiscussionsReplies: 4Last Post: 18-06-2009, 03:37 AM -
Questions about Beverage Air freezer
By BlueVanACD2005 in forum Trouble ShootingReplies: 14Last Post: 10-01-2009, 04:29 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM
