    tommydnguyen's Avatar
    tommydnguyen Guest
    Need help with Beverage air freezer>
    I have an e series beverage air freeze ef48-1as 2 door reaching -in freezer. Recently not freezing the food. I noticed that Ice was built up in Evaporator and defrosted and clear out all the ice but when turn back on I don't see the evaporator fan running. Are the fans suppose to run the whole time? I not what could possible problem be...food get soft and unit does seem working.
    Re: Need help with Beverage air freezer>
    Maybe the fan won't start until the coil has got cold to prevent blowing defrost water about.
    tommydnguyen Guest
    I am not sure if the fans are suppose to run all the time or at the restart..aren't the fan suppose to run to circulate the air? Unit is not freezing though...all the food got soft and temperature is at 20 degree... Any advice
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Fans will only run when fan delay thermostat closes on temperature, then switch off when defrost cycle engaged. Sounds like fan delay is not working or fans are faulty BUT you have to check compressor pressures as well to make sure evaporator is getting cold enough for fan delay to work.
    38
    a beverage chiller and you are freezing food. Or have I got the wrong end of the stick somehow.
    Feb 2008
    adelaide sth.oz
    1,015
    sounds like combination defrost termination,fan delay switch is at fault.
    Apr 2001
    79
    5,071
    35
  1. Designing Systems for Beverage Coolers
    By mmaragh in forum Fundamentals
    Last Post: 15-08-2010, 02:38 AM
  2. Beverage cooller / wine well
    By mvtop in forum Domestic
    Last Post: 18-04-2009, 11:58 PM
  3. Questions about Beverage Air freezer
    By BlueVanACD2005 in forum Trouble Shooting
    Last Post: 10-01-2009, 04:29 PM
  4. Beverage cooler testing methods: coca cola vs. ISO
    By MrsFreeze in forum Commercial
    Last Post: 03-04-2007, 10:40 AM
  5. Formula to size Refer unit for Beverage cooler
    By mccoolair@yahoo in forum Commercial
    Last Post: 25-01-2006, 08:42 AM
