Thread: Novice again
16-01-2011, 03:00 PM #1
Novice again
simplw question what tmperature would you guys expect liquid and suction on a japanese split unit in full cooling R22,R407 ?
16-01-2011, 03:57 PM #2
Re: Novice again
hi welder, how you doin ? you know you will have to go to the wholesalers and get yourself a compaitor or 2, depending on which gassas you are going to be working on .
on R 22 58psig is the lowest pressure you can have before the evap starts to freeze up,
on R 407 its 68psig,
but I did notice , < when I was on the tools < a long while ago , that the more modern chinese type heat pump ran on a lower psi < suction< possiblt cos they have phisilities to defrost?
hope this helps welder ,, sedgyLast edited by sedgy; 16-01-2011 at 04:19 PM. Reason: more duckin bad spilling lol
16-01-2011, 09:53 PM #3
26-01-2011, 03:44 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Novice again
Temperatures you are asking are dependent on TD of heat exchangers, their condition (which reflects on actual TD), and temperatures of air which goes in them.
TD depend on heat exchanger construction and amount of air/water.
Check this thread.Last edited by nike123; 26-01-2011 at 03:51 PM.
Novice Really Needs AC Help & Advice - Plasma Cooling Question!
By Bazzy in forum Air ConditioningReplies: 8Last Post: 11-12-2009, 07:17 PM -
rack novice question
By friocold2008 in forum Supermarket RefrigerationReplies: 15Last Post: 06-12-2009, 10:57 AM -
Daikin help for a novice
By liamroys in forum Trouble ShootingReplies: 3Last Post: 28-07-2006, 01:17 PM
