16-01-2011, 01:59 AM #1
Fujitsu inverter split A/C 50Hz and 60Hz are interchangable?
Fujitsu inverter split systems for America and Canada are 208-230volt 60Hz (note: two hot lines) while those of Europe are 220-240 volt 50Hz (note: one hot line and one neutral). Since the compressor is designed to vary speed, could the American version work safely and efficiently with 220-240 volt 50Hz? Does the unit use the same board?
16-01-2011, 10:58 PM #2
Re: Fujitsu inverter split A/C 50Hz and 60Hz are interchangable?
What do Fujitsu say about it?
17-01-2011, 10:25 PM #3
110v 60hz fridge freezer runnin on 110v 50hz
By helpneeded552 in forum ElectricalReplies: 8Last Post: 22-02-2011, 05:16 PM -
110v 60hz in a country w/ 220v 50hz
By dkupinsky in forum Technical SpeculationsReplies: 22Last Post: 02-08-2010, 03:20 PM -
50HZ compressor on a 60HZ circuit
By dan wong in forum Technical SpeculationsReplies: 28Last Post: 13-06-2009, 05:52 PM -
50Hz vs. 60Hz, okay to run at slower frequency?
By pezagent in forum CommercialReplies: 10Last Post: 26-05-2003, 07:48 PM
