Results 1 to 18 of 18
Thread: Hot Gas Defrost
    Apr 2001
    2,099
    27
    Hot Gas Defrost
    Installing a new system, just realised evaporator does not have electric heaters. its a 20 Kw evap
    So , Im going to have to go hot gas defrost
    The check valve.........does it go after the expansion valve
    Its better I look like an idiot asking, but I want to get it right
    Thx
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    The chek valve should be installed parallel to TEV. The chek valve direction-to liquid line.
    Vaidas
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    Ignore that I wrote above if your system has one compressor and evaporator. In that case you don't need the chek valve, if the liquid line has a solenoid of course.
    May 2004
    southern england
    69
    86
    Re: Hot Gas Defrost
    If your system is a single evporator and unit, then you will not be able to use a two pipe hot or sat gas defrost method and will have to use a three pipe system. Take a 1/2 or 5/8 tee off the discharge and pipe (or top of reciever, if it contains enough volume of sat gas vapour to effect defrost) to a tee between the expansion device outlet and the distributor with a solenoid valve for control. The suction gas pressure to the compressor should be controlled with a crankcase pressure regulator. In practice it is a pretty crap way (Comp nearly always runs 100% of the time and eventually fails) of effecting a defrost and you would be far better to fit defrost heaters.
    it's only a fridge, fix it. ;)
    Jun 2005
    California
    394
    Re: Hot Gas Defrost
    Oct 2001
    Nottingham UK
    5,668
    Re: Hot Gas Defrost
    Hi Wambat.
    The link doesn't work for me
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Hot Gas Defrost
    I think that the link should be without the
    like this i think it will work http://www.sporlan.com/5-158.pdf , nothing should be after the final extension of a file , that's what's i've mentioned from my experience in computers
    Dec 2001
    Cleveland
    41
    Cool Re: Hot Gas Defrost
    Hello Aiyub
    The post the guys put up for you from Sporlan is NOT for defrost purposes this is for low load conditions/capacity control on a/c systems you would need more controls i.e. suction accumulator/pan loop/ solenoids/etc for defrost use
    regards
    Dave G
    Jun 2005
    California
    394
    Re: Hot Gas Defrost
    Dave is correct, I believe this is better http://www.bmil.com/ballyrefrig/thermosaver.htm
    Oct 2003
    5,630
    34
    Re: Hot Gas Defrost
    Hi mate,
    Is this a freezer application?
    My opinion, I should install heaters, vene if you have to remove the evaporator once again.
    Like the posters said, if it's a 1 evap/1 cond situation, you will also need to to install a TEV on your condensor and 2 check valves. A lot of work and the material will cost more than the heaters.
    In case of a reversal cycle, you will also need a large enough liquid separator.
    Otherwise your compressor will pump liquid after a defrost.
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    Quote Originally Posted by Peter_1
    Hi mate,
    Hi Peter, what do you mean "you will also need to to install a TEV on your condensor " and "In case of a reversal cycle, you will also need a large enough liquid separator"?
    Apr 2001
    2,099
    27
    Re: Hot Gas Defrost
    Hi mate,
    Peter.
    Yes, it is a freezer room.
    Ive decided to install heaters, instead of going the hot gas defrost route
    I ordered 8 straight heater coils, cost £20.00 each. Total cost £160.00
    Fitted them today, now I dont have to worry about check valves and compressor burning out, etc
    Thanks for everyones help........I appreciate it.
    Abe
    Oct 2003
    5,630
    34
    Re: Hot Gas Defrost
    Quote Originally Posted by vaidas_78
    http://www.bmil.com/ballyrefrig/thermosaver.htm is one example
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    Sorry Peter, but I still can't see TEV on the condenser.All I can see is a 3-way solenoid valve.
    Oct 2003
    5,630
    34
    Re: Hot Gas Defrost
    You're right, this wasn't a good example.
    This is a better one http://www.books4hvac.com/rb/Heat_Pumps1.htm
    I hadn't look very weel when I posted this link.
    They use a 3 way valve instead of a 4 way
    BTW, what do you guys think of the Thermosaver system?
    Two liquid separators, one with a succool coil in it.
    Why 2?
    Is the subcool coil in defrost mode acting as a small condensor?
    Where is the heat coming from to defrost the coil? Only from the absorbed power of the compressor?
    Where happens the expansion?
    What about excessive compressor SH?
    For smaller applications like small ice machines and small evaporators this will work fine but for the system like Aiyub, I doubt.
    Any comments on this?
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    Hi Peter, it looks to me you have been confused.Thermosaver is not a heatpump and it use a 3way valve for defrosting, not for a cycle reversing.In this system the hot gas and a liquid are sharing the same pipe,so it needs 3way valve and two chek valves.
    The subcool coil in the defrost mode forces the liquid to boil in accumulator.
    The crankcase pressure regulator(pos.H) protects compressor from overloading during the defrost cycle and also evaporizes some liquid.
    The vaporized refrigerant picks up some heat passing through the suction line. As it passes through the compressor, the heat of compression raises the temperature to such a level that it continues to heat the evaporator and remove the frost.
    Regards Vaidas
    Oct 2003
    5,630
    34
    Re: Hot Gas Defrost
    .....,so it needs 3way valve and two chek valves.
    I hadn't noticed valve H, thought it was a shut-off valve.
    Valve H act while defrosting as an AEV.
    I do understand the schematic, but you're confirming what I'm saying -I think- thermodynamically seen, the only heat we're adding to the system is the absorbed power of the compressor on that moment, which will very litlle due to the very small DP the compressor is working.
    Further more, the liquid coming from the evaporator encounters a serious temperature drop when entering the right accumulator (with the subcool coil)
    So the hot discharge gasses going to the evaporator for defrosting will undergo a serious cooling, so the net availbale heating effect will seriously decrease.
    Jan 2005
    45
    14
    Re: Hot Gas Defrost
    Hi Peter,
    The main parameter for the discharge temperature(and also pressure) increasing is a compression ratio. Higher compression ratio - higher the temperature at the end of the compression.Low temperature compressors have the high compression ratio.What's why they cannot be used in high temperature aplications as a high suction pressure would increase the discharge temperature and pressure greatly.For this reason thermosaver is using the crankcase pressure regulator. During a defrost cycle DP is not very high but it's normal .Of course the suction gas temperature affects the discharge temperature but just slightly.
    What I don't like in this system is that the hot gas shares the same pipe with the liquid.At the beginnig of the defrost the hot gas will push the liquid all along the line and evaporator to the suction line.What's why they are using two liquid separators,I thik. What would happen if the liquid line would be very long?
    I would rather choose a three pipe system whith the one accumulator.
    What do you think?
  1. Hot gas defrost
    By adam5365 in forum Transport
    Last Post: 04-11-2007, 06:23 AM
  2. Hot Gas defrost suction pressure regulation
    By 87mustang in forum Technical Speculations
    Last Post: 05-08-2005, 07:25 AM
  3. Hot Gas vs. Electric Defrost
    By herefishy in forum Technical Discussions
    Last Post: 08-03-2005, 07:50 PM
  4. Electric Defrost
    By iceman007 in forum Trouble Shooting
    Last Post: 12-06-2004, 09:34 AM
  5. Hot gas defrost
    By Volnei in forum Fundamentals
    Last Post: 18-05-2002, 12:26 PM
