    mkashifk's Avatar
    mkashifk Guest
    Filter dryer selection
    hi
    I have 40 tons air cooled water chiller, it has two 20 tons compressors(reciprocating type),section pressure is 65psig and head pressure is 280psig.
    unfortunately filter drier specification tag is no more on it and i have to change it .please help me to suggest correct filter drier for my system.
    BR
    mkk
    11,025
    Re: Filter dryer selection
    We can't see your machine from here so can't be too positive.
    Start here with Sporlan to see if you can identify the model.
    http://www.sporlanonline.com/catchalls.shtml
    Oct 2003
    5,630
    34
    Right on the spot Brian
    Oct 2007
    manchester
    5,639
    45
    drier cores-do an acid test whilst u change them
    R.K.Selvam's Avatar
    R.K.Selvam Guest
    First you confirm is it Filter drier core or normal Filter drier.Ther is some filter is there like 100% molecular sieves.anyhow youcan select if you have filter drier in the liquid line as per the line size you can select.otherwise if it is core how many core it contains in the shell accordingly you can select.
  1. Polyester Mesh Filter
    By back2space in forum Air Conditioning
    Last Post: 01-05-2010, 04:02 PM
  2. Filter dryer question.
    By wingman in forum Technical Discussions
    Last Post: 21-05-2009, 02:52 PM
  3. extra expansion valve and dryer port
    By CoolWell in forum Fundamentals
    Last Post: 07-10-2008, 03:10 AM
  4. Removing sweat on Filter Dryer dangers?
    By mooka in forum Domestic
    Last Post: 09-10-2007, 05:09 PM
  5. Replies: 7
    Last Post: 19-06-2007, 10:51 PM
