    Jan 2008
    Durban
    37
    21
    Refrigeration o ring material
    What O ring material can I use for R404,R134 and R22?
    Is there a material I can use across the general range of refrigerants?
    Nov 2006
    708
    23
    Re: Refrigeration o ring material
    Neoprene should be ok Nitrile is not compatible with HFC
    Sep 2010
    Kazakhstan
    36
    Dec 2008
    55
    In Durbs,we used to use "Viton" For R22/R12 and Nitryl for R134a, R407c etc. Bearing Man in Springfield park was the best, but that was about 13 years ago. Good luck.
    Somerset
    69
    4,709
    Quote Originally Posted by Sserrviceman View Post
    As I posted October last year.
    Which a simple search before posting would of revealed.
    http://www.refrigeration-engineer.co...ighlight=rings
    Well worth a read all the same chillman.
    Jan 2008
    Durban
    37
    21
    Awesome, Thanks for your help guys!!
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
  2. Presentation material for supermarket refrigeration
    By Kevin Yeo in forum Supermarket Refrigeration
    Last Post: 01-02-2007, 12:13 PM
