    Sep 2009
    uk
    14
    should have been a plumber
    Thanks sedgy.perhaps you could assist with another one? checking the temps on the liquid and suction i get 5 Deg (70psig) liquid 13 deg suction (92psig) so +7 accross the evap.Does that sound correct for R22 and what would you expect for 407 and 410a?
    Oct 2008
    mallorca, spain,
    75
    768
    Re: should have been a plumber
    sorry welder , I am sure one of the mods will come on to tell you the correct answer to this one.
    regards sedgy
    Sep 2009
    uk
    14
    Thanks anyway !! enjoy the sun.
    Any mods got a reply?
    Aug 2007
    Sydney
    52
    1,083
    23
    Hi Welder
    Sorry I'm not a mod but for hi temp application (ac) I would expect around 60 - 70 psi for r22 suction press. If you give us more detail on the system your working on we could help further. As for the r4XX I'm not sure but you could check on a pressure temp chart.
    Mar 2006
    Lancashire
    1,859
    28
    Quote Originally Posted by Welder View Post
    You need to use a refrigerant comparator to convert the temperatures to pressures.
    For all high temp applications your saturated suction temp should be around 0C (depending on the load) wether you are using R22, R407c, R410a the temps stay the same yet the pressures differ which is why comparators are used.
    Marc
  1. Uk young plumber of the year
    By El Padre in forum Chit Chat & Service Stories
    Last Post: 05-12-2010, 07:04 AM
  2. plumber to refrigeration engineer???
    By rueben2288 in forum Air Conditioning
    Last Post: 05-01-2010, 07:12 PM
  3. Vaillant Air Conditioning
    By Prince Vaillant in forum Air Conditioning
    Last Post: 02-08-2008, 08:03 PM
  4. Change of Job
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 20-09-2003, 03:26 AM
