14-01-2011, 06:48 AM #1
Cooling capacity of domestic refrigerators
how to find the cooling capacity(refrigeration effect) of a household refrigerator .?
for example : how much cooling does a 165litre fridge provide,consuming an average of .98kw hr/day.?
14-01-2011, 02:37 PM #2
Re: Cooling capacity of domestic refrigerators
can anyone kindly reply.? its pretty urgent guys..
thanks in advance
14-01-2011, 05:43 PM #3
14-01-2011, 06:31 PM #4
Check compressor details. Take a few pressure & temperature readings in the system - Te,sat ; Tc,sat ; SH ; SC ; compressor power - plug it all into Coolpack & you should get a very good idea of what the fridge is doing.
You could also try a rough matching from the compressor table. Trouble is that this does not always contain the typical operating point of your final refrigerator.Last edited by desA; 14-01-2011 at 06:44 PM.
14-01-2011, 07:29 PM #5
15-01-2011, 04:08 PM #6
thanku sir..im a novice and do not understand the terms u have used..can u kindly explain briefly.?
07-03-2011, 07:56 PM #7
As an approximative estimation, multiply the compressor absorbed power by 2.75 and you will get an idea of the refrigeration capacity. (for above zero coolers)
Best regardsEngineering, sciences, math, physics and my brain will generate "not responding " soon
Need Help- Calculating Net Cooling Capacity with R-22 Replacements
By terrywilson in forum Air ConditioningReplies: 9Last Post: 12-10-2010, 06:23 PM -
Loss Cooling Capacity?
By rinsoproud in forum Technical DiscussionsReplies: 4Last Post: 30-06-2010, 07:58 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Hi all, need of help on testing of domestic refrigerators
By eager in forum New to REReplies: 6Last Post: 29-11-2006, 05:09 AM -
Regulation of cooling capacity
By npaisnel in forum DomesticReplies: 13Last Post: 08-02-2002, 11:22 PM
