Results 1 to 16 of 16
    Dec 2010
    South Africa
    41
    Cordless flaring tool?
    Hi, all the best for the new year to everyone.
    On americantoolsupplyinc.com they're selling a cordless flaring tool cft300, does anyone know what this is? How it works etc?
    What is the best way to make a flare?
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Cordless flaring tool?
    The ITE eccentric flaring tool comes with a 3/8 drive adapter which can be used with a service ratchet or cordless drill .
    It costs about 130 euro over here,i dont see the benefit in using power tools for flaring as it is the preparation of the pipe face to be flared that is important.
    A good reamer or de-burring tool is the key.
    The cft -300 comes with flare blocks that clamp onto the pipe
    and drill with a recessed cone that connects to the clamp
    Overrated and over priced.
    Stu
    Tool's ? check ! Condom's ? check !
    Aug 2001
    Gold Coast, Australia
    600
    28
    Can't see the point unless you're doing hundreds a day & it saves enough time to pay for itself.
    Dec 2010
    South Africa
    41
    Thanks, guess the old fashioned way is best then. Are there any fancy/advanced reamers or de-burring tools available?
    Jun 2009
    Lusk , Dublin
    1,115
    Stick to the pen-type and inner-outer and you cant go wrong.
    Have a look here.How advanced do you want it to be ? The end result is the same..If done right..
    http://www.google.ie/images?rlz=1C1D...i=image_result
    Stu
    Jul 2007
    Australia
    1,845
    I use things like these:
    http://www.amazon.com/dp/B002PHVJ9W/...SIN=B002PHVJ9W
    The pen type didn't work for me unless I kept it really sharp.
    The standard 45 deg inner outer take too much meat of the end of the pipe before fully deburred, so higher chance of cracking when flaring.
    But the long 15 deg tapered reamers with 6 cutting edges take the burrs off quickly for me. Got mine from an automotive parts shop for stuff all (supercheap for you aussies)
    3,856
    I've always used a stanley knife to debur the pipe for flaring. I have a pen style one too with the swively blade and one of those cone ones, but always end up using the stanley knife!
    (still have most of my fingers....)
    Dec 2010
    Ireland
    339
    15
    I find the cone cutters great. Don't apply too much weight and you get a great finish
    Nov 2006
    708
    23
    Yeh I use cone cutter too nice and smooth and ya can get the upto 1 1/8 , just pop in the battery drill
    Sep 2003
    ISRAEL
    72
    4,248
    Leatherman Super tool 300 doe's it for me.
    Check this one, http://www.mastercool.com/pages/flaring_tools.html
    Jul 2007
    Australia
    1,845
    I find the blades too brittle, chip and break too easily, plus get blunt too quickly.
    Hell, I shave with a single edge blade, and when it's too blunt to shave with, I put it in my tool box.
    It's still is sharper than a stanley knife blade and cuts better and lasts longer.
    Only last week I was struggling to cut insulation with a new stanley blade after a few lengths. Today I was breezing through it with an old used razor blade.
    Dec 2010
    South Africa
    41
    Wow, never knew there was such a huge range of deburring tools. Those hydraulic flaring kits must cost quite a bit.
    3,856
    I've got a Lenox saw like this one that i use for cutting armaflex etc though i'm sure it was cheaper than that!
    It takes blades from a sabre saw so you can use metal or wood blades in it.
    http://www.plumbersurplus.com/Prod/L.../60118/Cat/415
    Jon
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Don't be so lazy Jon, shove the pipe in the insulation using baby powder. Really annoying trying to reseal armaflex after its been gutted. Glue eventually lets go, duct tape gets messy, especially with that cheap stuff, and compressing the insulation reduces its efficiency. Wet areas grow mold and go slippery then attract rats/mice.. yuk! .. Moving on, Pipe cutters. Had one that wouldn't stay in the groove. One turn then its off up the pipe cutting some weird thread. Tossed it and bought Rothenberger with deburrer on board.
    Jul 2007
    Australia
    1,845
    Quote Originally Posted by Cool Force View Post
    I watched th e video on that site, not exactly a time saver or takes less effort anyway.
    regarding cutting and gluing insulation, I only cut and glue insulation when I have to fit it to an existing unit. Like replacing insulation on pair coil that's disintegrated, or rodent/fire damaged insulation
    Jun 2008
    NZ
    102
    I can't really agree with the principal of automating something a basic as a flaring tool.
    However, having had a wrist injury (from a brand new drill of good brand but poor design, that's a whole 'nother story) I can see a time when something like this might be an option - or I could just send staff to the job...
  1. Replies: 9
    Last Post: 29-01-2011, 10:28 PM
  2. Looking for a tool
    By iwashere339 in forum Tools and Calculators
    Last Post: 13-09-2010, 04:08 AM
  3. Flaring tools
    By jimbo82 in forum Tools and Calculators
    Last Post: 10-03-2010, 08:13 PM
  4. flaring kit
    By paul_h in forum Tools and Calculators
    Last Post: 23-09-2007, 03:04 PM
  5. want good price r410 flaring tool in aust ?
    By peter1927 in forum Tools and Calculators
    Last Post: 24-11-2005, 05:48 AM
