    rb123's Avatar
    rb123 Guest
    Arneg fridge replacement fan
    I am looking for a arneg fridge replacement fan.
    The fans are made by Mavib. This is the actual fan .mavib.com/inglese/products.htm The Energy Saving but it does not have the white transformer connected to it. Maybe its an updated model.
    The ring is actually connected on so it is not detachable fromt he fan itself.
    The wattage i can see on the fan itself is either 20-5w or 29-5w. its not easy to read but it wouldnt make sense it being 29-5w. so i would assume it is 20-5w fan.
    where can i get a replacement one from?
    thanks
    rb
    May 2006
    scotland
    31
    Re: Arneg fridge replacement fan
    hi m8,
    it sounds like youre looking for a 5w ring mount fan motor, measure the diameter of the ring and get in touch with any branch of climate centre.
    44
    3,795
    38
    Does it look like this,
    http://application1.cdesign.it/mavib.../ESM.33-36.jpg
    If so as acb says any ref wholesaler should be able to supply an equivalent.
    Or you could phone Arneg and ask for their spares department.
    Jon
    scotland
    758
    13
    hi, there is a company called eurogel, peter will sort you out on any problem you have with any parts on any arneg case, THERE NUMBER IS 01283 210055.
  1. Warm Fridge
    By leongf in forum Technical Speculations
    Last Post: 16-04-2010, 08:42 PM
  2. extending temp range of domestic fridge
    By kubcat in forum Domestic
    Last Post: 06-01-2010, 04:21 PM
  3. Fridge Thermostat replacement
    By LucasAdamson in forum Electrical
    Last Post: 30-11-2009, 12:14 PM
  4. Replies: 26
    Last Post: 09-03-2009, 11:04 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
Tags for this Thread
