Results 51 to 100 of 236
Thread: 1/2²
Hybrid View
08-01-2011, 10:18 PM #1
Re: 1/2²
Indeed, that is the combined and then the general is PV = mRT and the universal uses moles instead of mass and because mole for mole the energy per volume.pressure.temperaure is the same for every gas the constant R is the universal whereas for the general the gas constant is specific to that gas because the mass per mole depends on the molecular mass. The universal is then PV = nRT where n is the number of moles. If n or m are one then the formula are:
PV = RT (general gas constant R)
PV = RT (universal gas constant)
PV is energy and RT is energy so PV = RT is basically saying Energy = Energy
Energy is work or tha ability to do work, work is force x distance and force is mass x acceleration.
Standards are dropping right across the western world though more so in some countries than in others.
I meet a lot of techs who have done level 3 but do not feel they still understand PH charts or more importantly psychometrics and many want to understand fans and ducts. This is why I am designing a 2 day physics training course that is purely HVAC&R orientated - no nonsense stuff - nothing excessive - just what is required for a tech to be a good commissioning tech confident with why the ducting or water systems or ahu's are designed the way they are and why they are commissioned the way they are and what room to move do they have when they need to modify systems.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
08-01-2011, 10:42 PM #2
Re: 1/2²
[quote=DTLarca;216626]
Ideal gas equation?Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
08-01-2011, 10:52 PM #3
Re: 1/2²
Boyles, Charles and then the derived combined then general equations assume ideal gases.
This is why PH charts are preferred to equations for vapour compression calcs because vapours have molecules that do not behave entirely independent of each other - nearer the saturation zone, as is the case even with compressor discharge gases, there is friction between the molecules and so the powers involved in processing vapours are higher than those calculated for ideal gases.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
08-01-2011, 10:05 PM #4
Re: 1/2²
And i agree with Goober,,
Remember we are here for a good time, not a long time.
Trust me i'm a Fridgy.
08-01-2011, 10:10 PM #5
Re: 1/2²
I to understand, but how it is explained becomes of importance.
Acceleration; what is it?
if you have a body,mass or material that at apoint of time is travelling at a speed and at another point in time is travelling at a faster speed then it has accelerated. Note; "speed is also called velocity"
We firstly have to determine what speed is. Speed is how much distance has been travel in a pre set time, for example 5m/s, this means in one second that the mass have travelled 5 meters (Note, speed can be shown in many ways, "miles/hr, ft/sec")
Now that we understand speed, we can look acceleration.
If we have a starting speed for example 10m/s we then measure one second later and the new speed is 11m/s, we can see that the actual speed has changed by 1m/s.
so how do we write this
change in speed= 1m/s
how long did it take to change this speed= 1 second
Therfore is 1meter per second per second = acceleration is 1m/s/s.
Hopefully this shows a method, with useful information to aid understanding, the gramma may be poor, but thats no my fortie!Last edited by mad fridgie; 08-01-2011 at 10:14 PM.
08-01-2011, 10:24 PM #6
Re: 1/2²
Yes, it is that the sort of approach that needs to be taken. I will have to scan the articles and email them to you - I don't want to be writing the physics articles on here then publishing them - it wouldn't make sense - so I am just sticking to particular points - at the moment that point is "working with fractions as pertains to elementary physics"
Knowing the difference between speed and velocity is important. For instance the difference between speed and velocity is important in developing an understanding of efficiency.
Velocity/speed is the efficiency factor.Last edited by DTLarca; 08-01-2011 at 10:26 PM.
08-01-2011, 10:34 PM #7
Re: 1/2²
We have to presume that those that we are trying to teach no little, we therefore need to start at the beginning slowly bring up the level of knowledge and understanding, if we move to fast, then all is lost!
The difficulty may be where we lie within the peer group, when you at at your oxford group then yes you should be using every word in the dictionary, but when talking to me, if I have learnt it on the Jeremy Kyle show, then I do not know it!! (bit of humour aids leaning0
09-01-2011, 07:55 AM #8
Re: 1/2²
Speed is the magnitude of velocity. Velocity has both magnitude & direction - it is a vector quantity.
http://en.wikipedia.org/wiki/SpeedLast edited by desA; 09-01-2011 at 07:58 AM.
09-01-2011, 08:17 AM #9
Re: 1/2²
What I was trying to show, is how training should be built,
What is magnitude and what is a vector quantity?
We are looking at training techs, so theorectical excellence has to be tempered with practrical realism, (with time more greater levels of theorectical)
So going back to speed and velocity, each is shown in the same method M/S, KM/Hr, etc, so practically is the same.
The nature of engineering is that it always leads to further questions and increase requirement of knowledge
08-01-2011, 10:23 PM #10
Re: 1/2²
Moles dig up my garden, so before using "Mole" as terminilogy, should you not first explain how Mole is related to mass.
08-01-2011, 10:38 PM #11
Re: 1/2²
Lol, I don't want to be discussing all that yet
Avogadro found that if you had equal volumes of different gases but all the gases were at the same pressure and same temperature then they would have equal numbers of molecules.
He realised that the reason all these identical volumes of gases at the same pressures and temperatures weighed differently was because they each had different molecular masses.
He then decided that if he weighed 2 grams of hydrogen which had atomic mass unit arbitrarily set at 1 he would measure the volume and call that the gram mole. At 0°C and atmospheric pressure 2 grams of hydrogen took up 22.4 litres.
Anyway - you and nevgee are hijacking my thread
I don't want to be getting into all the meat of this stuff here - I want to fine tune the finer principles such as at the moment fractions and physics.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
08-01-2011, 10:44 PM #12
Re: 1/2²
Ok I'll back off .....
08-01-2011, 11:35 PM #13
Re: 1/2²
Mad Fridgie,,,what's a Mole?
08-01-2011, 11:47 PM #14
09-01-2011, 12:21 AM #15
Re: 1/2²
Mad Fridgie,
Thought so, it's the same here.Remember we are here for a good time, not a long time.
09-01-2011, 01:48 AM #16
Re: 1/2²
1/2/1/2=.25
broken down in sequence
1/2 = .5
.5/1=.5
.5/2= .25
09-01-2011, 01:52 AM #17
Re: 1/2²
09-01-2011, 02:02 AM #18
Re: 1/2²
09-01-2011, 02:34 AM #19
Re: 1/2²
Here we go, scroll down to complex fractions and have a quick read...
http://en.wikipedia.org/wiki/Fraction_(mathematics)
I'm going to print that link off and read it tomorrowOnly the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
09-01-2011, 05:13 PM #20
Re: 1/2²
Exactly as I saw the equation.
Frank said 1/2/1/2 = 1/2/2 = 0.25
But 1 half divided by 1 half is 1.
1/2/1/2 is the same as 1/2 divided by 1/2 = 1 because 1/2 goes into 1/2 just once and precisely just once.
Frank no doubt took one look at this and thought "Gawd - what was I thinking".
If it was written (1/2)/(1/2) then I would have looked at it differently. There are obviously limitations to the way formula's can be written in the forum
09-01-2011, 05:25 PM #21
Re: 1/2²
If we were to say it is permissible to call the question ambiguous then we would have to give all possible answers as for something to be ambiguous there has to be two or more possible answers - not just one - if only one answer is given then the question was not perceived as ambiguous but was merely misunderstood.
If the question has more than one possible answer then they might include those derived from interpretations such as...
1/(2/(1/2)) = 0.25
1/((2/1)/2) = 1
But to say that 1/2/1/2 just means 1 divide 2 then divide 1 then divide 2 is to treat 1/2/1/2 as an instruction sequence rather than a fraction. If it is to be treated as a fraction then is has to be broken down into numerators and denominators.
Now, can we have a fraction such as 1/2/2?
No we cannot. A fraction must clearly demarcate numerator from denominator.
The convention, in the absence of brackets, is to start at the top identifying numerator then denominator then numerator then denominator.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
09-01-2011, 05:44 PM #22
Re: 1/2²
09-01-2011, 05:53 PM #23
Re: 1/2²
Indeed
m/s/s when treated with the conventions universally applied to fractions in the western world (perhaps everywhere else too) is interpreted as m/s/s/1 which was the whole reason for me starting the thread because I come across so many people who do not understand this and at the same time I believe this to be one of the key reasons people struggle to make full use fo the tools of physics.
If m/s/s was not implicitly m/s/s/1 then we just could not get to m/s²
m/s/s/1 is the same as m/s x 1/s = m/s²
And if you accept that then you have to accept also that 1/2/1/2 = 1 otherwise you are flat out contradicting yourself.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
09-01-2011, 05:46 PM #24
Re: 1/2²
Seems like you are going back to your old ways my friend.
Do you ever admit to being wrong, or in fact admit to possibly making an error?
There must be a psycological term for someone that is never wrong..........
Count me out of any further responses.
09-01-2011, 06:04 PM #25
Re: 1/2²
Are you taking about me Frank?
Firstly - I have never changed my ways and never will - my ways and me are the same thing - they are inseparable.
When I know I am wrong I out loud announce that I am wrong. But right now I believe I am right about this - I could be wrong - that seems to me to be possible - that is why I started the thread - to weigh up a balance of arguments for and against. But so far I believe the arguments for are very much stronger than the arguments against and so this far I genuinely believe your arguments (not you) to be wrong and my arguments (not me) to be right.
Someone who is never wrong is a genius of extraordinary levels. But if you read David Hume's works you would understand that we can only ever learn from making mistakes. If I know a good amount of stuff then it is because I have more experience than others at being wrong about the same stuff at some stage.
Since you can only learn from being wrong and making mistakes - because being right is probabilistic and never a certainty - I put these questions up so that I and others can become more right out of experiencing more often more mistakes. If you are not willing to make mistakes then you are also not willing to learn.
Do you honestly believe - without doubt - that your answer is the correct one?
Do you know what the definition of arragance is?Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
10-01-2011, 08:45 AM #26
Re: 1/2²
So Frank - do you not feel compelled to admit error yet?
Does "Count me out of any further responses" mean "Oh **** - if I hang around here I'm going to have to sooner or later admit I was wrong"?
You know, the difference between an arrogant antagonist and a sincere one is that the arrogant one will merely rebut your claims without explanation whereas a sincere one will at least try offer argument and evidence.
Of course it is possible you genuinely think you are right? I think that would be very odd - it would very much surprise me - but it could still just be that you genuinely believe you are right - in which case you are not obliged to admit you are wrong - it is sheer nonsense to ask someone to admit they are wrong when they feel sure that they are correct.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
09-01-2011, 01:53 AM #27
Re: 1/2²
I agree with Slingblade...........
09-01-2011, 08:33 AM #28
Re: 1/2²
Begin with Newton's Laws of motion, then build up all the required components. It is all fairly straightforward - high-school maths.
Bringing in this highly-unconventional continued fraction approach will, I fear, only lead to more confusion.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
09-01-2011, 08:45 AM #29
09-01-2011, 08:49 AM #30
Re: 1/2²
http://en.wikipedia.org/wiki/Newton's_laws_of_motion
There we go.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
09-01-2011, 09:02 AM #31
Re: 1/2²
http://en.wikipedia.org/wiki/Dimensional_analysis
This may also be helpful, Marc.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
09-01-2011, 06:08 PM #32
Re: 1/2²
I think i've found my level
09-01-2011, 06:31 PM #33
09-01-2011, 06:41 PM #34
09-01-2011, 06:09 PM #35
Re: 1/2²
Frank - use this online calculator to calculate 1/2/1/2
http://www.calculatorsoup.com/calcul.../fractions.phpOnly the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
09-01-2011, 06:43 PM #36
Re: 1/2²
^ lol...
09-01-2011, 06:52 PM #37
Re: 1/2²
Tits or tyres, nothing but trouble
09-01-2011, 06:55 PM #38
10-01-2011, 12:16 AM #39
Re: 1/2²
Chilli, neither as you would be dead, but.. thats just an opinion. Cartoons come to mind,whistle.... followed by splat and a cloud of dust. Coyote lives to recalculate why both condensing units fell at different speeds.
10-01-2011, 05:02 PM #40
10-01-2011, 09:07 AM #41
Re: 1/2²
I do think it comes down to how it is written, if I remember rightly, if you were calculating a fraction, the fraction was in a small font, with the comand in a larger font 1/2/1/2
The answer would then be clearly 1Last edited by mad fridgie; 10-01-2011 at 09:39 AM.
10-01-2011, 09:52 AM #42
Re: 1/2²
Yes, the whole point is to establish a certainty of understanding with regards to the units analysis when considering say specific heat capacity kJ/kg.k or acceleration m/s² because no matter how much anyone does not like it these truly are just peculiar cases of complex fractions as in 1/2/1/2
That makes it kJ/kg/K/1 and m/s/s/1
I see no available argument to support any implied claim that a school child being introduced to fractions and ratios will be taught that 1/2/1/2 means 1 divide 2 then divide 1 and then finally divide 2. I think this is sheer nonsense. More likely the result of 30 years absence from studies than any erudition
I wholly reject the proposal that 1/2/1/2 is not a fraction having no numerator or denominator but is instead merely an instruction sequence.
There is no evidence available to me in any of my math books or any where on the web.
Therefore the matter is not ambiguous - there are not two or more different ways to interpret the arrangement 1/2/1/2. It can only be (1/2)/(1/2) and any other interpretation is a mistake.Last edited by DTLarca; 10-01-2011 at 09:54 AM.
10-01-2011, 09:51 AM #43
Re: 1/2²
I have read this thread from start,,,and i find watching paint dry far more interesting.I reckon coolrunnings post was spot on,yes go back and have another look at it and i think everyone will agree,,but unfortunately some people are too thick to absorb anything other than their own opinion.
10-01-2011, 10:03 AM #44
Re: 1/2²
go to excell and type
=1/2/1/2
what is the answer?
Type as you have written, no f***ing with fuctions, or brackets.
whats the answer?
10-01-2011, 10:17 AM #45
Re: 1/2²
That is your mistake Mad Fridgie
The convention with complex fractions taught to school kids and used in physics is that 1/2/1/2 must be read as (1/2)/(1/2) and not any other way.
A computer sees the number and function string as an instruction and so for you to get the right answer using excel you have to inform excel of the convention it is supposed to use and so with you string of instructions you also have to include convention instructions.
My question is not "What would excel do?" but rather "what is the convention?".Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
10-01-2011, 10:29 AM #46
Re: 1/2²
You Quoted
"There is no evidence available to me in any of my math books or any where on the web."
Well excell is one of the most commonly used pieces of software, so by nature is convention.
Flynn verses the state, are porno mags convention, he proved it was due to how much porno films were watched.
I also clarified that Bodmas was used or that fractions were written in different fonts, to distinguish between fractions and string instructions.
What was the answer on excell, you never answered the question?
10-01-2011, 10:40 AM #47
Re: 1/2²
I work with excel all the time - I produce little windows applications in Pascal - I do not have to do it in excel to know what excel will do.
You could say that because I am aware of what excel will do I am aware that it is not immediately obvious to everyone that 1/2/2 is the same as 1/2² and hense the thread. It has the answer but the method to go from one to the other contradicts the method excel follows.
Consider again what Frank says: 1/2/1/2 = 1/2/2 = 0.25
How on earth does Frank establish that 1/2/1/2 is the same as 1/2/2?
In other words how does Frank turn a 1/2 into a 2?
Why did he turn only the bottom 1/2 into a 2 and not also the top half. If he also turned the top half into a 2 then he would have 2/2 = 1.
Also then, why did he not instead just turn the top half into a 2 which would have given 2/1/2 = 4 or by your standards = 1
I think you guys are just trolling - seriously - I can't believe this nonsense.Last edited by DTLarca; 10-01-2011 at 10:46 AM.
10-01-2011, 10:58 AM #48
Re: 1/2²
Did you not quote there was no evidence?
simple answer "yes or no"
I proved there was. so you are wrong, accept the truth
I asked you undertake the equation, which you did not. So what is the answer, do it?
Then you can accept that yours is not the only method of achieving a result.
10-01-2011, 05:32 PM #49
Re: 1/2²
Sorry can't agree with this. Since when did Exel have the right to define what convention is or is not.....
there are so many mistakes made now because tech's have drifted away from the idea of standard formats and convention.
I get annoyed when I see tech manuals written with kw instead of kW and kWhr when they mean kW.
DTLarca may have a very annoying approach to his lectures with his hidden meanings and criptic questions but I have to agree with him that there are standards and technical formats that need to be adhered to if we're to understand what it is that others are trying to explain.
Taking a stance that Exel is a format that is accepted is nonsense. My calculator will give me all sorts of ridiculous answers if I punch in the numbers without following the rules (BODMAS) etc. That' why those rules are there so we all can work on an apparently level playing field.
I'm off to the pub.Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
10-01-2011, 07:56 PM #50
Re: 1/2²
Excel, does not have the right to be used as convention, but because it is used heavily it has become by nature a convention. (I am not say this is right or wrong,)
very early on i did bring up BODMAS.
The point of my arguments is to make you think,
All information has to clear and in context with the data around it. (while agree that we should be using a common method, practically we do not)
Marc has given examples of travelling, the context has determined the method of calculation.
