Results 1 to 11 of 11
    JPaul's Avatar
    JPaul Guest
    Question Mini-Frig Components
    As a non-frig Engineer, I have the task of locating mfg's in the US of Refrigerator components including compressors. Can anyone lead me to some competative local (US) vendors ?. It would be greatly appreciated. Thanks in advance for your help.
    Apr 2001
    79
    5,071
    35
    The ACH&R News publishes an annual "Directory & Source Guide" for it's subscribers.
    www.achrnews.com
    Feb 2001
    Tampa Florida
    1,076
    Are you an OEM buyer? Give me a hint: How much would you want to pay for a particular something or the other. Most of us in these forums are not factory people, but I would be happy to point you in the right direction, either through manufacturers, wholesalers, or OEM's.
    Dan
    JPaul's Avatar
    JPaul Guest
    Dan
    Dan thanks for your reply. We are an OEM and are planning a new refrigerator product line. I need everything required for a refrigerator. As far as price is concerned, I need it at about a Taiwan price.
    JP
    Feb 2001
    63
    264
    You came to the right board for help on design but pricing etc is probably not any of our specialties. Where you from JP?
    :D
    Dean
    Subzero*psia
    Extinction is simply proof of failure to adapt.
    JPaul's Avatar
    JPaul Guest
    I'm from Chicago. I'm not looking for prices from anyone here just names of manufacturers in the United States that produce refrigeration components such as compressors etc. I thought I made that clear in my original post.
    Thanks anyway. I will need some assistance in the near future on design also.
    Dec 2001
    Cincinnati, Ohio, USA
    63
    258
    23
    How about making them easier for a service tech to repair? You ever try to replace an evaporator? With some of them, you might as well camp out at the shop...it takes forever to do some of them.
    Also, why not use a REAL heat exchanger (cost about $20 each) and skip brazing the cap tube on the return line - it makes for faster service & replacement when needed as well as saves some Kw's. Related: avoid the glass tube defrost heater...use the type that resembles an oven heat coil.
    Another thing...how about putting the defrost timer in the bottom front or an easy to get at place in the rear...those too can be a pain to try to replace/test.
    Slow evaporator fans cause poor cooling...maybe design the ductwork to accomodate aging fans so that when they get slow, they can still do the job effectively. Some of those fans cost a left kidney just to buy (Are you listening Whirlpool?)
    Sizing - I won't buy a fridge that I can't put a 2 litre bottle of soda upright on the top shelf (hint) or one that weighs so much it takes two men & a boy to move.
    Maybe make the fridge so all service/repairs can be done from the back - no more dismantling the innards to get at the fan, evaporator, thermostadt, defrost timer, drain line, etc. An access panel in the rear would make things quite nice!
    Just a thought...maybe use an evaporator that's 20% larger than the minimum needed? I assume you will be required to use R134a. With the larger evaporator, you might get the temperature down below zero deg F without running a fridge for 27 days straight (LOL)
    Zolar
    Feb 2001
    Tampa Florida
    1,076
    Good suggestions, Zolar. I got hung up looking for an American manufacturer of small compressors and found nothing. You picked up on the design aspect. Maybe that's where we can contribute.
    You have made a good start, although I would disagree with some of your details.
    If Jpaul would entertain ideas along this line, that would be great. But if we are talking about manufacturing something in Chicago, I don't see anything happening. And if it is to be mass-produced anywhere, you can forget niceties such as serviceability contrivances that add even a single dollar to cost of producing the refrigerator.
    But things can be placed better and more conveniently for servicing without adding cost.
    And there ain't nothing wrong with advice regarding where we put things on the shelves. There are only a few convenience stores with cups that fit into my cup-holders in the car, for example. They get all my business, simply because of that.
    Dan
    Dec 2001
    63
    258
    23
    Handleless doors can save a little.
    Coils up the back should be cheaper than coil/fan combo underneath.
    Perhaps make the outer door shell out of plastic instead of metal? It would save on shipping weight and you could get by with pivots/hinges that aren't as strong.
    Plain white paint should be cheap.
    Even if you couldn't afford a real heat exchanger, you could simply braze or soft solder the high and low sides together starting 6 inches from the compressor and for about 4-6 inches in length...I have done that before with good success. That would get you by with the cheaper compressors (smaller locked rotor)
    Zolar
    PS have you tried looking at Johnstone supply for compressors?
    JPaul's Avatar
    JPaul Guest
    Talking
    Zolar
    Thanks for all the good advice. Tell you what, you design the hardware and placement within the box, let me know where to purchase the components stateside and I'll do the rest. I can not seem to find compressors or most anything mfg in the USA for Refrigerators.
    Dec 2001
    63
    258
    23
    Are you proposing some sort of partnership perchance?
    Zolar1@hotmail.com
  1. mini micro-brewing
    By dave in forum Hobbies
    Last Post: 26-01-2011, 01:43 AM
  2. auxiliary components information
    By mohamed khamis in forum Tools and Calculators
    Last Post: 27-04-2006, 01:20 PM
  3. Mini liquid Chiller design
    By Sockit2me in forum Fundamentals
    Last Post: 10-02-2006, 06:38 PM
  4. Replies: 17
    Last Post: 11-02-2004, 02:23 AM
  5. Mini Ducts
    By subzero*psia in forum Air Conditioning
    Last Post: 24-06-2001, 12:19 AM
