    Jul 2009
    Australia
    44
    81
    Reason to keep Fridge / Window Unit Upright always?
    I've heard lots of salesman mention that window units and fridges should not be tipped over on the side and if they are they need to be left for half an hour before you can turn them on........ something about "The gas being out of the compressor".
    Is there any truth to this, would there be parts of the refrigerant that are always in a liquid state and could possibly slug the compressor if you lean the fridge or air con unit on the side for an amount of time before straightening it up and starting it?
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Reason to keep Fridge / Window Unit Upright always?
    A lot of truth
    Its not about the gas so much ,it's about the oil in the compressor flowing out of the sump if its tilted over.
    Allowing it to stand after transport is to enable the oil to return to the compressor.
    You wouldn't start your car engine if you thought there was no oil in it .
    Or would you??
    regards
    Stu
    Jul 2007
    Australia
    1,845
    Did you make a post on WP or ocau about this?
    Main thing about fridges, the motor can fall of it's springs partially, so will 'clunk' every time it cycles off for the rest of it's life. So always move fridges in their vertical position and don't jerk them about
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    WHAT is the deal with this transportation problem. Put it on a trolley if its a fridge, or 2 persons to lift air-conditioner about -Upright Had a post "why wait" in old wives tales but really, who is stupid enough to move these items on their side or upside-down?.. Mike.
    Jul 2009
    Australia
    44
    81
    No transportation inst a problem I was just curious of the effects of tilting a fridge on it's side.
    Even if it was tilted and the oil escaped the sump, wouldn't there be residual amounts of oil to provide initial lubrication? Or is there a chance the oil can pool up at the inlet and slug the compressor?
    Cheers/
    11,025
    Quote Originally Posted by Z2TT View Post
    No transportation inst a problem I was just curious of the effects of tilting a fridge on it's side./
    Why turn it on it's side?
    Do you buy a car and turn it on it's side, no of course not. It's the same with a fridge, the door opens one way and is designed for that purpose. If it was designed to lay on it's side they would install the compressor at 90° from where it is now.
  1. Vrv
    By tgoonter in forum Air Conditioning
    Last Post: 11-01-2011, 06:25 AM
  2. Warm Fridge
    By leongf in forum Technical Speculations
    Last Post: 16-04-2010, 08:42 PM
  3. Problem with ducted Daikin
    By jutty in forum Trouble Shooting
    Last Post: 23-07-2007, 05:34 AM
  4. Help! fridge freezer probs
    By Glenreed in forum Trouble Shooting
    Last Post: 06-01-2006, 10:51 PM
