Results 1 to 29 of 29
Thread: Stal screw
Threaded View
10-01-2011, 09:35 PM #5
Re: Stal screw
Hey GHAZ,
R59K is a Mk2 STAL Mini. The Mk1 versions were produced up to code F. 9 indicates that it has a gearset which gives a 5900 rpm. at 50 Hz.
These compressors are pretty reliable if serviced properly. Overhaul requires the right tools (toolkit).
Do you have any specific questions? Maybe I can help you. I can ask my colleque in the UK if he has some technical info for you.
The Screwdocor
Service manual for STAL Screw compressor
By pfwousv in forum Industrial CompressorsReplies: 3Last Post: 23-08-2011, 07:17 PM -
S87 stal screw
By RANGER1 in forum Industrial CompressorsReplies: 7Last Post: 12-02-2011, 07:32 PM -
Stal vertical screw compressor
By Kota.Kumar in forum Technical DiscussionsReplies: 8Last Post: 06-11-2010, 08:17 AM -
STAL SRM SCREW compressor
By graeme ellis in forum Industrial CompressorsReplies: 7Last Post: 15-03-2007, 02:01 AM -
Stal Screw Compressor R5-mkii 100kw
By REFSOO in forum Trouble ShootingReplies: 1Last Post: 20-01-2007, 01:09 AM
