    johnnyLaw's Avatar
    johnnyLaw Guest
    PVE Oil for Sanyo mini split
    Hello All!
    Thanks to the community for providing such a valuable place for HVAC information!
    Okay, so here is the question. I have just purchased a Sanyo mini split unit 24k btu with low ambient (to zero degrees) to replace the identical model that has been burned out for over a month.
    It says that I should use PVE as the refrigerant oil to connect the lineset. My question is, where can I buy this? After talking with two of the supply houses here in Atlanta, they claim they don't know any difference between the oil and they only sell one kind!!!! NOw, I know that there are plenty of R410a systems out there so I doubt that all the contractors are using mineral oil on these systems.
    Can someone please recommend where I can buy a very small amount of PVE based oil online or in Atlanta locally? Thank you! I've been searching for some time and to no avail. This can't be this hard!
    Jun 2009
    Lusk , Dublin
    1,115
    Re: PVE Oil for Sanyo mini split
    Try google Idemitsu Lubricants America. They offer a free sample of PVE
    Regards Stu
    Tool's ? check ! Condom's ? check !
    johnnyLaw's Avatar
    johnnyLaw Guest
    Quote Originally Posted by stufus View Post
    Regards Stu
    Thanks very much Stu!
    For everyone's info, if you would like a free sample of PVE lubricant for your R410a systems, please email customerservice@ILAcorp.com with your request. Cheers!
    Jun 2009
    Lusk , Dublin
    1,115
    The best stuff ,is free stuff !!!!
    Jul 2005
    Ireland
    57
    164
    Hi Guys
    Sanyo oil is usually Vs68 second oil when purchasing it make sure the Viscosity is correct. Some PVE oils are 28 or 32 seconds which are unsuitable for SANYO equipment
    T
  1. Wiring to indoor mini split.
    By Telstar_2112 in forum Air Conditioning
    Last Post: 06-07-2010, 10:00 PM
  2. Servicing a LG Mini Split 410a
    By wrangoth in forum Trouble Shooting
    Last Post: 28-04-2010, 06:59 PM
  3. Mini split system heating, but not cooling well.
    By tirider in forum Heat Pumps
    Last Post: 06-11-2009, 09:17 PM
  4. Amcor mini split control board
    By alive2live in forum Air Conditioning
    Last Post: 25-10-2009, 01:06 AM
  5. Prime mini split
    By efrain in forum Air Conditioning
    Last Post: 09-06-2009, 04:15 AM
Tags for this Thread
