Thread: More problems with Scotsman MV12
05-01-2011, 06:31 AM #1
Hi all.
After getting the harvesting problem fix, and was going great for months, its now started another fault.
What happens this time, rest the unit, both green lights come on, the fan starts, the water starts to flow, than after about 10-20 seconds, a click is heard inside, the fan stops, but the water still flows, then a little time later, water stops. You can reset the machine, then starts again, can remove the white cover, machine knows this as it brings up the full led, close the lid, green led flashes then starts, but again stops after the time, so switch appears to be ok, but have noticed the water temp is cool, but not cold, but that could be due to the short time is running for.
Any ideas, do have some gaurges, but have never used them, so may need some assistance on the use of them.
Rob
08-01-2011, 06:10 PM #2
Re: More problems with Scotsman MV12
hi rob,
if it has a infra red bin stat/bar, give its sensors a clean, also most scotmans have a fan pressure that will switch the cond fan on/off so dont worry too much about this.
Scotsman MV12 does first harvest, and then nothing
By Boof in forum Trouble ShootingReplies: 11Last Post: 22-11-2010, 03:55 PM -
Oil problems with a dual temperature pack.
By Chunk in forum Supermarket RefrigerationReplies: 33Last Post: 11-09-2008, 03:29 AM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
