Thread: External heat with City Multi
Threaded View
06-01-2011, 12:27 AM #1
We have a site with one PUHY outdoor unit and eight PDFY ducted units. Each PDFY has an attached hydronic coil. Each coil is controlled by a dedicated actuator on a centralized manifold. We are using PAC-YU24HT external heater adaptors on each indoor unit to call for hydronic heat.
The design is for the hydronic heat to be the primary heat source. The PUHY should either be the backup heat source (preferred) or not provide heat at all.
On the outdoor unit SW5-2 enables "backup heating", but we can't find a way to disable the heat pump or make it the backup.
Does anyone know if this is possible?
City Multi Headache
By garytreez in forum Air ConditioningReplies: 6Last Post: 12-12-2010, 09:59 AM -
Overall heat transfer coeficcient fo ammonia heat exchanger
By luissandoval in forum NH3Replies: 2Last Post: 13-03-2010, 04:34 PM -
City Multi - Inverter Speed / Noisy Check Valve
By Contactor in forum Air ConditioningReplies: 2Last Post: 22-04-2009, 02:49 AM -
Mitsubishi city multi
By chrisboy27 in forum Air ConditioningReplies: 3Last Post: 09-02-2009, 05:17 PM -
Low head pressure Versus Heat reclaim.
By taz24 in forum Supermarket RefrigerationReplies: 17Last Post: 20-03-2008, 11:47 AM
