Results 1 to 2 of 2
    qazman's Avatar
    qazman Guest
    Question Daikin- E7 error code
    Hi.
    The Daikin air conditioner that we own stopped working all of a sudden. Following a search through the internet, I was able to find out using the remote control that the error code was E7. The E7 error code corresponds to a malfunction of the outdoor unit fan motor. How can I fix this?
    Any help would be much appreciated.
    Feb 2008
    386
    13
    Re: Daikin- E7 error code
    Malfunction of Outdoor Unit Fan Motor (
    E7)
    Remote Controller
    Display
    E7
    Method of
    Malfunction
    Detection
    Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
    fan motor runs.
    Malfunction
    Decision
    Conditions
    When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
    running conditions are met
    When connector detecting fan speed is disconnected
    When malfunction is generated 4 times, the system shuts down.
    Supposed Causes
    �� Malfunction of fan motor
    The harness connector between fan motor and PC board is left in disconnected, or faulty connector
    Fan does not run due to foreign matters tangled
    Clearing condition: Operate for 5 minutes (normal)
    Troubleshooting
    Caution
    Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
    occurred.
    Replace the outdoor unit fan motor.
    Connect the connector.
    Remove the foreign matter.
    YES
    NO
    Are fan motor
    connectors
    disconnected?
    NO
    YES
    Is the pulse input?
    Check No. 11
    Check for pulse input
    for number of rotations
    on the outdoor unit
    PC board.
    Replace the outdoor unit PC board.
    YES
    NO
    NO
    YES
    Is there
    any foreign matter
    around the fan?
    Can the fan be
    easily rotated by hand?
    (S2584
  1. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  2. Daikin assistance or LACK of it!!
    By brianocallaghan in forum Air Conditioning
    Last Post: 15-07-2010, 11:23 AM
  3. Mitsi City Multi VS Daikin VRV
    By sumsor in forum Fundamentals
    Last Post: 14-07-2010, 05:54 PM
  4. Daikin AC parts from UK
    By skel00 in forum Air Conditioning
    Last Post: 05-04-2009, 01:24 PM
  5. Fixing Daikin A3 Error
    By Stuffy in forum Air Conditioning
    Last Post: 27-03-2009, 06:02 AM
