Results 1 to 16 of 16
Thread: Fan coil unit
05-01-2011, 05:01 PM #1
Fan coil unit
Could anyone explain to me the operation of the unit and then how do you test or check if the following is working on the unit
1. Heater bank
2. Actuator on return water valve from unit
And how do you connect up the controllers. Explanation or practical diagram will be appriciated.
05-01-2011, 09:17 PM #2
Re: Fan coil unit
Johan, I appreciate that you are a Junior and hopefully you will progress over time.
You seem to be asking some very basic questions, not a problem, but do you have access to written text books or is your reading material limited?Last edited by Brian_UK; 06-01-2011 at 08:23 PM. Reason: Grammar
06-01-2011, 03:51 AM #3
Re: Fan coil unit
Politely put Brian_UK.
06-01-2011, 09:18 AM #4
Re: Fan coil unit
Hi!
Polling to Brian_UK .
Do you have some data? watts, power, any sizes,
if you have some more info we can help you welcome
07-01-2011, 03:45 AM #5
Re: Fan coil unit
Hi Brian. My info in South Africa is limited. I just dont seem to find info on the time off equipment that i am working on in the day to day job. Mechanically i can figure things out but on the electrical side I am not good at all. If you can help me find info or a place where i can read up on equipment I will appricaite it.
Thanks Cheers
08-01-2011, 12:19 AM #6
Re: Fan coil unit
OK Johan, we'll have a look around for some reading matter for you.
08-01-2011, 09:54 AM #7
Re: Fan coil unit
Thank You that will really help alot. Even if you can just give me a name of a good book that I can buy it will also help alot. I am not expecting too get everything for free. With some many books out their I just dont know which one too get.
10-01-2011, 09:49 PM #8
Re: Fan coil unit
Principles of refrigeration by Dossat. Often just referred to as Dossat.
10-01-2011, 11:26 PM #9
Re: Fan coil unit
A useful data/function book...
http://www.lorencook.com/PDFs/Catalo...ok_Catalog.pdf sorry, it's in Imperial
Also check the rest of their site
http://www.lorencook.comBrian - Newton Abbot, Devon, UK
11-01-2011, 04:03 PM #10
Re: Fan coil unit
Which part of SA are you based.
11-01-2011, 06:55 PM #11
Re: Fan coil unit
His profile says Brackenfell; I think that's on the Western Cape.
11-01-2011, 08:30 PM #12
Re: Fan coil unit
if there is a duct frost sensor installed, trip this, the heater bank and 3 way actuator should open fully, if not back to the drawing board!!
alec
11-01-2011, 08:33 PM #13
Re: Fan coil unit
Johan
Try this for some light reading!
http://customer.honeywell.com/techli...s/77-E1100.pdf
Alec
11-01-2011, 08:52 PM #14
Re: Fan coil unit
Some fan coil info here..
http://www.johnsoncontrols.com/publi...w-profile.html
Use right hand More Info panel to get info on units, piping and controls layouts.Brian - Newton Abbot, Devon, UK
12-01-2011, 04:36 PM #15
Re: Fan coil unit
I am based in Cape Town. Brackenfell area like Brain said Press. Thanks for all the info. Time to read up. My thanks to all.
12-01-2011, 04:42 PM #16
Re: Fan coil unit
You might be interested in the two e-books which I posted on the forum today for further reading. check them under refrigeration books. I thought you were closer to me here in Pretoria. Its okay anyway.
Multisplit fault
By back2space in forum Air ConditioningReplies: 67Last Post: 19-10-2010, 11:07 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM
