    Jul 2005
    Belarus
    Compressor for island case
    Hello experts,
    I need make island case with built-in condensig unit and capillary tube.
    The air temperature inside may vary from minus 6 C to plus 6 C.
    Should I use LBP or MBP Embraco compressor for condensig unit ?
    Which must be evaporation temperature?
    Thanks for any advice
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Compressor for island case
    Tralex , i didn't understand what you want to build . . . please explain
    Jul 2005
    Belarus
    Hello botrous,
    I'm sorry for my inefficiency to explain what I want.
    Now I drew my question.
    Thank you
    Apr 2001
    2,099
    27
    You need MBP or LBP assuming you want to evaporate around -16C
    to achieve -6C
    You need to check Embraco table for that compressor to see if it can achieve the required duty at that evap temp
    Dec 2004
    LEBANON
    44
    854
    21
    I agree with Ayub . . . send an email to the Embarco and they can help you select the right compressor for your application or see the Embarco tables
    Aug 2005
    South Africa
    55
    You also need to check the condenser size if you intend using the existing one. The safest would be to use a standard condensing unit sized to the (new) capacity of the existing evap. Remember the evap will give slighlty more capacity at the high temperature (depending on the delta T of course).
