Thread: panasonic inverter cu/cs12 ckp
27-12-2010, 11:06 AM #1
please help when i start air con.on cooling mode he works very good but when is on heating mode he works about 3 minutes and turn off after 3min. he start again. 3min.start 3min off the pressure is good when pressure is 20bars current is 4 A ON heating mode compressor stop where is problem air.con. don't displayed any errors.
27-12-2010, 06:34 PM #2
Re: panasonic inverter cu/cs12 ckp
hi dance. tell me is the set point < on heating < 2c more than the room temp,? sedgy,
27-12-2010, 07:49 PM #3
I found problem. sensor of the heat exchanger on indoor unit.
28-12-2010, 09:11 AM #4
ok dance , well done, thanks for letting us know, sedgy,
02-01-2011, 12:19 AM #5
any picture of sensor - where is itr? thx!
Panasonic CS1873KR inverter air cond wont switch on
By supamerc in forum Air ConditioningReplies: 4Last Post: 12-12-2010, 12:15 AM -
Panasonic Inverter Pipe Sizes?
By bundysnake in forum Air ConditioningReplies: 1Last Post: 15-03-2010, 09:23 AM -
Panasonic inverter -Power factor protection
By Blackbird in forum Air ConditioningReplies: 3Last Post: 28-06-2008, 01:17 PM -
Panasonic Inverter
By wat180 in forum Air ConditioningReplies: 3Last Post: 13-05-2008, 06:13 PM -
Panasonic air-con inverter unit
By Baron in Spain in forum Air ConditioningReplies: 4Last Post: 04-12-2007, 11:34 AM
