Results 1 to 1 of 1
Thread: Dynamic Condenser - Modelica
24-12-2010, 11:39 AM #1
Hello,
I have to build a refrigeration system (compressor, condenser, valve, evaporator and a PI controller to stabilize the superheat coming from the evap.). I need to make the condenser and the evaporator dynamic. I have solved the problem with the evaporator.
But my problem is the Dynamic Condenser. I need to make it calculate the Pressure knowing the outlet parameters from the compressor. Does anybody know how to find the Temperature of the superheat if we know only the enthalpy and the mass flow coming out of the compressor ?
I hope I made myself clear!
Thanks in advance!!!
P.S. I have to build it in Dymola Modelica!
Install condenser in opposite position its built for?
By Henry. in forum FundamentalsReplies: 24Last Post: 19-08-2010, 10:50 PM -
Parallel condensers Shell and tube paralle with Evaporative Condenser
By Herschmidt in forum NH3Replies: 2Last Post: 08-06-2010, 11:12 PM -
How to measure COP (evaporative condenser)
By Juho in forum Technical DiscussionsReplies: 5Last Post: 04-06-2010, 07:08 PM -
Evaporative Condenser system COP
By Juho in forum CommercialReplies: 0Last Post: 03-06-2010, 09:23 AM -
Air Cooled Condenser Leakage Problem with R-404A
By RADHAKRISHNARAO in forum Technical DiscussionsReplies: 19Last Post: 30-07-2008, 12:21 PM
