    Dec 2010
    Iran
    33
    What is the role of screws?
    Auckland
    74
    3,357
    37
    Re: What is the role of screws?
    Under the cap is a grub screw that locks the stator in position. Compressor looks like a Carrier 06E
    Nov 2006
    708
    23
    With no capacity unloading valve
    495
    21
    Hi its carrier 299 pw with a 40hp winding, you need a 1 1/8 or 27mm socket to open it and underneath it , it has a metal washer which is used to seal any leaks from the crankcase , the long nut screws on to a threaded grub screw which locates on the motor stator and stops it moving and also aligns it with the rotor
  1. Are Copeland screws any good?
    By garyb in forum Commercial
    Last Post: 08-06-2010, 06:47 AM
  2. Kobelco Screws
    By Cold Down Under in forum Industrial Compressors
    Last Post: 19-08-2008, 11:17 PM
  3. Hitachi Screws
    By cmac in forum Fundamentals
    Last Post: 29-05-2008, 09:56 PM
  4. Help about British standard for screws
    By Josip in forum Tools and Calculators
    Last Post: 17-12-2006, 11:00 PM
  5. Commissioning Bitzer Screws
    By Andy in forum Commissioning
    Last Post: 22-11-2006, 09:12 AM
