Results 1 to 30 of 30
15-12-2010, 11:10 PM #1
List of tools that are carried in van
hi, I was wondering if anyone has a list of tools equipment neccesary to be carried in a van for self employed / sub-contractors, just so I can get an idea.
I am at college and wont be qualified for another 2 years, but am looking to build up a tool set so I am prepared when I finish my training.
thanks
16-12-2010, 07:16 PM #2
Re: List of tools that are carried in van
well a good start would be:
a set of gauges
vac pump
benders
cutters
flaring tool
multimeter
clamp meter
screwdrivers movers etc
rotaloc key
extension lead
comparator
brazing equipment
refrigerant
drills
a selection of breakers contactors overloads and controllers
universal fan motors
probes
swager set
brazing rod
the list goes on
16-12-2010, 08:16 PM #3
glass hammer
long stand
flux capacitor
skirting board ladder
16-12-2010, 10:10 PM #4
a box of holes, brass magnet (I got caught on that one ) and the best one when sent to the stores by a fitter....a long weight.
serioulsy though, a must is a Mapp gas gun
Don`t go overboard with buying expensive hand tools ie Snap On, over time you`ll find you`ll leave them on site. I know I have and I kick myself when I think of a spanner costing £30 left in a plant room. The only top notch stuff I get is allen keys and Pozidrive/Phillips screwdrivers.
Good luck for the future.
16-12-2010, 10:41 PM #5
haha thanks for the list, and some funny jokes. . wish I was a bit younger and hadnt heard them before
what would be a reasonable price to kit a van out to a good standard?
£3,000 ?
21-12-2010, 02:45 PM #6
20-12-2010, 02:13 PM #7
Good idea to add to the list I think:
1/2" socket set
1/4" mini socket set
Silicone!
Hammer!
PVC glue, WD40, silicone lubricant, cork tape, thread tape, duct tape
grinder
rotary tool (dremel)
Megger
Thermometer
masonary drill and core drill
laptop full of manuals
waffle pad
level
drop sheet
wet and dry shop vac (cleaning up plus suction to suck out on blocked drain lines)
dustpan and brush
garden hose, rope, tie down straps, 4ft steps, 6ft steps, 10ft steps 18ft extension ladder.
short odd bits of copper tubing in case you have to braze in a section
capillary tubing for the same reason
Bearing pullers
schreader valve cores, schreader fitting + tails, core removal tool and caps.
deburring tools
flare unions to extend you gauge lines or 72" gauge lines (actually both)
refrigeration oil, driers.
capacitors, fuses, transformers, contactors, relays, soldering iron.
edit: forgot leak detector, expanders, nitrogen + regulator, metal holesaw drills, and half of a hardware store for bolts/screws/rivets/washers/plugs etcLast edited by paul_h; 20-12-2010 at 02:34 PM.
16-12-2010, 10:58 PM #8
i wouldnt go kitting it out with new gear keep your eyes peeled for special offers or 2nd hand things like expanders etc
i would recommend a set of decent snips knipex or similar and also irazola drivers and a decent fluke meter
19-12-2010, 10:30 PM #9
I like to carry items in my shirt pocket as well, its a bugger when bending into a freezer though. 2 pens/pocket knife/240 test pencil/marking pen/ small screwdriver/pt chart/bic lighter/wallet/small note pad(for female phone numbers...kidding..). Have never been able to find a pocket extension ladder or sonic screwdriver.. Mike.
20-12-2010, 11:11 AM #10
Couple of things without thinking too long about it is Magnetic Snap On screwdriver(had mine for 12 years now) and a torch
In the words of David Byrne, Well...How did I get here?
20-12-2010, 03:33 PM #11
Some wood blocks and a lenght of 3" x 2".
They are useful for proping things up, drilling into, levering things, etc.
21-12-2010, 01:03 AM #12
Don't forget the tin of tartan paint for touch ups, or hammer glaze and hammer in tin.
OK joke.
21-12-2010, 02:53 PM #13
Always buy good quality screwdrivers as there is nothing worse than the pozi driver that goes round.
As others have said, be selective with what you buy dependant on what type of equipment you mainly work on. You will gradually accumulate special tools which get rarely used, but might come in handy.Mobile A/C at its best, see avatar.
21-12-2010, 10:24 PM #14
Gets the better of me when tools, and spare parts become invisible. This becomes a daily frustration, i just put that driver down but hey... where has it gone? No-one else around, find another then Bam, its back.
12-01-2011, 02:37 AM #15
In case anyone is still listening, don't forget the spare bucket of steam, the piping stretcher for when you cut twice and it was still too short and of course... the propane powered skil saw.
12-01-2011, 07:10 AM #16
I find a sky-hook comes in handy when working outdoors with heavy gear.
Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
12-01-2011, 06:55 PM #17
whatever you have is never enough but the basics have to be a fluke tester 4 line gauges a thermometer a small socket set the rest depends on what you are doing ie domestic/commercial/industrial or put a card in the wholesalers and someone who retires may sell give you some kit
15-01-2011, 09:42 AM #18
If you get everything on this thread, its a truck you will need not a van
19-01-2011, 09:55 AM #19
Hammers ........lots of them
19-01-2011, 10:20 AM #20
dont forget the sparks for your grinder!
"Old fridgies never die, they just run out of gas!"
20-01-2011, 02:10 AM #21
a good accountant thats cheap
21-01-2011, 10:26 AM #22
20 B&H and cheep gin
OK this has turned into a farce now
but one sensible thing never compromise on tools
your tools put a roof over your head and food on the table
buy good quality once and look after themPaul
"KEEP IT COOL"
21-01-2011, 10:44 AM #23
some of my favorite tools are:
1/2 inch socket set plus a 1/4 or 3/8 set.
half moon file for pipe work etc
Large solid screw driver for bashing and leavering
permanent magnet for solenoid coils.
good allen keys.
Shroader removing tool to remove stem under pressure.
I do a lot of work on compressors and chillers, one of the best things i recently bought is a battery powered rattle gun. I got a makita one with a good drill. this is awesome. I also got with it a battery 4" grinder, circ saw and recip saw. (great but not essential)
21-01-2011, 08:46 PM #24
A compressor picker upper for hermetics is very useful, wouldn't be without one now.
03-02-2011, 02:24 AM #25
14-02-2011, 09:27 PM #26
Heres a short vid of me only just managing to pick up a 5hp L'unite with my picker upperer
http://www.youtube.com/watch?v=aoBCOjIlVx8
Note the tidy van....
Jon
11-02-2011, 11:25 AM #27
In Canada it would be coffee boy and he who runs to the truck in a downpour for the forgotten tool.
15-02-2011, 11:30 AM #28
laser thermometer is v. handy for checking if a rooftop unit is actually working from inside store, without having to access roof or scissor lift. I'm talking about the real high ceilinged stores.
my cant do without tool is a fluke voltage tester (pen type). Never leave home without it, saves a lot of time and helps prevent the old electrocution there.
15-02-2011, 12:09 PM #29
Don't forget a FriOil System!
Seriously, it is compulsory to have a recovery unit, maybe not in the van, but to own it at least. (and put it in the van in case of inspection,
I think that was missing... I guess you were waiting for my post
Regards,
Nando.
09-05-2011, 03:41 AM #30
Flaring tools
By jimbo82 in forum Tools and CalculatorsReplies: 5Last Post: 10-03-2010, 08:13 PM -
What tools do I need?
By davie in forum Tools and CalculatorsReplies: 6Last Post: 15-06-2009, 09:46 PM -
What Tools Will I Need?
By Fett in forum Tools and CalculatorsReplies: 10Last Post: 18-11-2008, 10:34 PM
