Thread: sporlan expansion valve question
15-12-2010, 07:21 PM #1
had one of these faulty,found the power element u/s the valve was 4 ton capacity,however in my stock i had a 1 ton valve so i removed the element from the good valve,now they are both on the same refrigerant r22,the question is will it work?
15-12-2010, 07:25 PM #2
Re: sporlan expansion valve question
If the power head is the same then why not?
15-12-2010, 07:37 PM #3
Yeah, they are the same, KT43 VC if my memory is correct. Fit a lot of them on Fabdec milk tanks as the chemical fumes in the dairy rots them out!
15-12-2010, 08:53 PM #4
thanks guys i thought as much
15-12-2010, 09:35 PM #5
as long as the valve bodys and gaskets match up and you use the correct orifice for the purpose or set the orifice correctly there will be no problem whatsoever.
thermostatic Expansion valve location
By dolce in forum Trouble ShootingReplies: 11Last Post: 05-07-2010, 03:26 AM -
Expansion Valve Selection
By raviperumal in forum Technical SpeculationsReplies: 12Last Post: 17-02-2010, 09:58 AM -
hunting expansion valve on airedale c/control
By knight rider in forum Technical DiscussionsReplies: 28Last Post: 10-07-2009, 11:21 PM -
thermostatic expansion valve sizing
By ank_gl in forum Air ConditioningReplies: 2Last Post: 03-03-2009, 03:22 PM -
Actual Expansion Valve Process
By AastroGuru in forum FundamentalsReplies: 11Last Post: 03-02-2009, 09:53 AM
