Results 1 to 50 of 88
Threaded View
18-07-2001, 01:07 AM #1
what is the best blend for low temp
I tryd frig 12 & 414b I have found some problems with frig 12 on the older systems and on systems not size right it will not pull down to temp has it will with r12 I know the size needs to right but its a hard sell all the custermer knows is it work just fine befor w/ frig 12 there is a diff. of coill temps from 414b .
r-414b has lower coil temp . what do you like to use 414b,mp66,frig12 what works for you and why the one I like is mp66 it looks close to r12 in low temp
MP66 & Compressor Overheating
By Intermez in forum Technical DiscussionsReplies: 111Last Post: 13-04-2010, 08:58 PM -
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
About gas blend properties (how can high pressure components condense?)
By DaBit in forum FundamentalsReplies: 17Last Post: 11-02-2004, 02:23 AM -
Multiplex For Low Temp and Medium Temp
By allanbaker in forum Technical DiscussionsReplies: 0Last Post: 28-11-2002, 10:15 AM -
Endless Freezer as Endless Cooler (10 door)
By herefishy in forum CommercialReplies: 95Last Post: 17-04-2002, 12:54 PM
