Results 1 to 8 of 8
    thumbsup's Avatar
    thumbsup Guest
    Servis M7554-2FF Fridge/Freezer Not working
    I have got problem with my Servis frost-free fridge freezer model M7554-2FF. a few weeks ago at beginning of development of the fault, its Min,Med and Max lights started to fluctuate, but both fridge and freezer worked ok. It developed another fault i.e. an excessive fan noise but it stopped by opening the fridge door. Both the fridge and freezer still worked. Eventually noise stopped, fridge and freezer stopped working.
    I kept it turned off whilst enquiring about its repair for a couple of weeks. I have turned it on. The flashing temperature lights at the control panel are stable as set, there is no excessive noise as mentioned earlier, the freezer compartment works ok but the fridge does not work. I have monitored fridge compartment's temperature as 10 degrees C.
    Any advice or help from the fellow members of the forum would be appreciated.
    I am unable to contact manufacture for technical advice or help as the company has gone into liquidation.
    Sep 2008
    Letsby Avenue
    359
    Re: Servis M7554-2FF Fridge/Freezer Not working
    You may find somone on www.whitegoods.co.uk who can help you
    May 2005
    newbury
    44
    13
    Defrost heater or timer are knackred the noise was the fan hitting ice
    Jul 2006
    norfolk
    737
    as roger says ^^^^ defrost heater fitted loads with same fault
    thumbsup's Avatar
    thumbsup Guest
    As I have mentioned freezer is functioning satisfactorily but fridge does not get cool.
    There is no noise other than compressor's noise. There is no presence of ice or frost in the freezer. I am a bit confused I thought there would have been ice/frost built up in the case of faulty defrost heater.There is no manual thermostat for fridge I can see! Is there a thermostat to control fridge?
    May 2005
    newbury
    44
    13
    Then it is either short of gas or a PCB fault. Is the compressor running continuasly?
    thumbsup's Avatar
    thumbsup Guest
    Thanks Roger for your interest in solving my problem.
    The compressor runs on of off maintaining the set temperature controlled by the thermostat. I have monitored temperatures of freezer as -19 deg C and fridge as +10 deg C. It seems to me faulty thermostat of the fridge compartment but I am unable to locate it. There is no rotary temperature control operating the thermostat fitted in most of the fridges. There are only three setting min, med and max temperature indicators at the panel on top of the unit.
    thumbsup's Avatar
    thumbsup Guest
    I am pleased to inform the fellow members of the forum who have tried to help me that the problem has been resolved. Root of the problem was a non-running evaporation fan fitted inside the freezer compartment.
    Blades of the fan had been catching the fan mounting bracket in turn producing the mentioned noise.The blades were wearing out such a way forming of hooks as results stopping the fan to run.
    The appliance is running satisfactorily now after fixing the fan but it is a mystery how the blades have been catching continuously over a long period as blades were found fitted in a good tight condition over spindle of the fan!
    Finally I would like to thank you all who have tried to help me with the problem.
  1. Replies: 3
    Last Post: 24-01-2011, 10:21 PM
  2. Replies: 1
    Last Post: 26-04-2010, 12:59 AM
  3. Replies: 2
    Last Post: 19-09-2009, 11:16 AM
  4. Ice Box on my Whirlpool Fridge/Freezer not working
    By Chouman in forum Trouble Shooting
    Last Post: 18-09-2006, 01:23 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
