14-12-2010, 11:39 AM #1
Indesit Tall Fridge Freezer not working after relocation !
Hello,
I have an Indesit tall fridge freezer model CG 1230 (approx 4.5 years old). I switched the unit off to defrost and move into my new kitchen. It defrosted ok. However now it has been relocated it won't get cold. Both the fridge and the freezer are refusing to work. I have switched it back off and left it for another 24 hours, switched it back on, but it's not freezing up. The unit is humming, but I haven't heard it 'kick in', it's a constant hum.
Is my fridge freezer dead ?????? Can anyone help ????
05-01-2011, 02:48 AM #2
Re: Indesit Tall Fridge Freezer not working after relocation !
Hi there,
If it has a mechenical timer just turn it a bit with flat screw driver, timer should be on the back some where.
Constant hum is the fan, common make the compressor run if u want it to freeze up.
I hope u haven't turned it ON at once after you moved it....
05-01-2011, 01:14 PM #3
There was a post a short while ago about starting friges once they were moved and the effects of laying them down. But during moving the internal motor may have moved off it's springs/mounts. If the circuits are made with power to comp and it wont run it could be tired. As an old trick I would use a DOL (direct on line) starter circuit with grunty capacitor then give it a kick (with my steel caps) if it didn't start which sometimes worked - of course I would have current meter attached during the test. Let us know how it goes or doesn't go.
Hotpoint Mistral Plus - Fridge Freezer
By cozzie121 in forum DomesticReplies: 9Last Post: 19-09-2010, 08:45 AM -
Candy fridge freezer working intermittently -HELP!
By charleylousy in forum DomesticReplies: 1Last Post: 17-08-2010, 08:44 PM -
Problem with fridge freezer
By narl in forum DomesticReplies: 2Last Post: 15-08-2010, 11:24 PM -
Whirlpool ARG 918WP (int F/F) Power on, but neither fridge or freezer working
By malwrx in forum DomesticReplies: 20Last Post: 14-06-2009, 05:51 PM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
