Thread: Cold Room Engineer required ASAP
14-12-2010, 11:09 AM #1
Hi people
I need a engineer to quote me to remove 2 cold rooms from a site in Leeds and re-fit them in Notts site ( I will arrange the transportation) I also need some diary fridges disconnected which I will also need connectingup in the Nottingham site. I need this work done ASAP (before Christmas) can anyone HELP?
Please inbox me on nav2bad@gmail.com
14-12-2010, 03:28 PM #2
Re: Cold Room Engineer required ASAP
Hello
Please do not post your email address in the open forums. If you do this, it opens you up to all sorts of problems. There is a PM (private message) system in place that you can use.
Kind Regards
Mark
14-12-2010, 11:22 PM #3
I need this work done ASAP (before Christmas)Brian - Newton Abbot, Devon, UK
14-12-2010, 11:32 PM #4
What your budget? Quick and short notice usually ends up costing more due to unplanned overtime and getting materials sent out quickly etc etc.
You are going to need a sparky too for power supplies and possibley a builder for and construction work that may be needed.
It might be a better plan to hire in some refrigerated trailers to get you going while you coldrooms etc can be installed in a more planned fashion.
Its just getting to the Christmas rush time when existing customer start to panic and want systems checked and long standing faults repaired.
Good luck!
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
Blind Cold room specs help
By frostedflake in forum Trouble ShootingReplies: 5Last Post: 13-03-2009, 01:49 AM -
CA cold room for storing apples
By igorv in forum Technical DiscussionsReplies: 1Last Post: 20-06-2008, 07:58 PM
