    wrx's Avatar
    wrx Guest
    Refrigeration questions
    Hi i have a couple of questions i want to ask because im not quite sure on how to work it out. The question is- A four cylinder compressor has a stroke of 12cm, a bore diameter of 10cm and is rotating at 680 rpm. It is delivering R134A to the tx valve at a condensing temp of 34 degrees C and the evaporating temp is -2 degrees C.
    I need to know the ratio of compression, the refrigerating effect and the actual refrigerating capacity if it has a volumertic efficiency of 78%.
    I would really like to know the formulas to work out these answers to please
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Refrigeration questions
    The equivalent pressure of 34°C for R134a is ?
    The equivalent pressure of -2°C for R134a is ?
    The pressure ratio is the first divided the second.
    The flow rate is easily calculated from the compressor displacement times the rotational speed.
    From there every other data is easily obtained.
    do your homework.
    Mar 2005
    638
    Wonder if this is a student trying to get his project work done.....
    ken
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
  2. Refrigeration Design Questions
    By UNCrefENGR in forum Fundamentals
    Last Post: 06-07-2010, 03:03 AM
  3. refrigeration warehouse questions
    By bnuncc07 in forum Industrial
    Last Post: 13-02-2007, 06:09 PM
