Results 1 to 9 of 9
    Jun 2005
    Madison
    61
    32
    Heat pump temperature control
    Hello All,
    I am trying to design a heat pump to provide hot water. The outlet water temperature is between 10 Celsius and 40 Celsius. Capacity is about 30KW. Does anyone know any simple ways for temperature control?
    When we design a chiller, a simple way for temperature control is hot gas bypass. Are there any simple ways for temperature control in a heat pump system?
    All suggestions and advices are appreciated.
    Vincent
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Heat pump temperature control
    can anyone , anybody send me a shematic of a heat pump , used for heating water . . . i am confused of you huys are talking about.
    thanks in advance
    Oct 2001
    Nottingham UK
    5,668
    To achieve this you would need a water cooled condenser with bypass (3 port) valve operated on discharge pressure, otherwise your rejected heat energy is lost to the air. Control of the system would be by storage vessel themostat.
    11,025
    Quote Originally Posted by botrous
    Have a look at this site - http://www.heatpumpcentre.org/
    Basically you replace the air cooled condenser with a water cooled condenser and utilise the waste heat transferred to the water circuit.
    Oct 2001
    Nottingham UK
    5,668
    Brian
    You make it sound like I know what I'm talking about
    Sep 2003
    ISRAEL
    72
    4,248
    We use them quite a lot,
    A 1/3 HP R12 compressor, running a 200 L reservoir
    The controll is a simple thermostate.
    No need for a SV cause the evaporater is the out coil.
    Chemi
    Dec 2004
    LEBANON
    44
    854
    21
    Thanks Brian . . . the link helped to understand what you guys are talking about
    Dec 2004
    Weihai,China
    800
    The easy type is using plate heat exchanger parallel to the hot water tank. Compressor is on/off by the thermostat of the water tank setup value. Japanese use the co2 system for heat pump water heater.
    Sep 2005
    India
    49
    30
    Hi Vincent,
    If you are talking about temp control hot water, you can simply use thermostat. Once the set temp is achieved, your system will shut off.
    You can visit www.nespl.com
  1. frostles heat pump
  2. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  3. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
  4. Building a wine cabinet
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
