11-12-2010, 10:34 AM #1
assistance required for carrier 30hcx chiller
hi folks just stripping down a carlyle compressor attached to the above chiller and im having problems removing the windings casing.
this maybe a stupid question but iv not got any manuals but do i need to remove the pullies as this seems to be trhe only thing holding the windings on the motor. that i can see anyway.
if any one has a manual for the overhaul of this compressor then u waould be a saviour.
thanks for looking folks.
await your reply.
cheers
matt
11-12-2010, 02:20 PM #2
Re: assistance required for carrier 30hcx chiller
on this machine you have an 06n twin screw comp the tolerances on this comp and minute my honest advice is to contact carrier for a replacement i have seen a few rebuilt and all have failed in a short time period
11-12-2010, 08:46 PM #3
Hi Matt.
Basically the rotor and stator are removed together with their housing.
After having removed the drive gear from the motor drive shaft.
As this requires the use of a special electrical heater (380F) and special puller using a hydraulic bottle jack.
etc.
I would recommend you discuss comp replacement with Carrier or a reman company.
Ps I assume you mean a HXC Chiller as opposed to a HCX?Last edited by Grizzly; 11-12-2010 at 09:11 PM.
York Chiller Manual Required
By cool_mariner in forum Air ConditioningReplies: 10Last Post: 19-11-2010, 09:30 AM -
Required temperature output from chiller is not obtained
By Bharat812 in forum Trouble ShootingReplies: 4Last Post: 25-10-2010, 06:17 PM -
Help required - York chiller YDAJ77
By scutworth in forum Trouble ShootingReplies: 4Last Post: 31-12-2009, 10:03 AM -
York Chiller help required
By RAVISEKAR in forum CommercialReplies: 9Last Post: 17-05-2008, 12:57 PM
