Results 1 to 8 of 8
Thread: S87 stal screw
    3,356
    S87 stal screw
    Can someone please assist in supplying shaft seal area dimention for S87 Stal
    Shaft seal area damaged & require correct measurement to repair seal area .
    Jul 2007
    Czech
    61
    373
    Re: S87 stal screw
    Single or double?
    3,356
    Re: S87 stal screw
    josef,
    Could only describe it as standard single seal .
    Machine is 7 yrs old & seal area approx 80mm
    What is double seal all about , is it something new?
    Somerset
    69
    4,697
    Re: S87 stal screw
    Hi Ranger.
    Sadly I only have the normal parts list which I assume you already have.
    That only has the minimum of information.
    Anyway good luck.
    Grizzly.
    Apr 2008
    215
    Re: S87 stal screw
    I think Josef may be refering to a modification made to the shaft seal which included an extra sealing ring to prevent oil from draining out of the shaft seal during idle periods.
    Ginge
    3,356
    Re: S87 stal screw
    Gingerair,
    Yes that was 1 upgrade also I think that the bellows that slides onto the shaft has 2 "0" rings now insead of 1 for higher pressure refrigerants.
    Apr 2008
    215
    Re: S87 stal screw
    Hi Ranger
    Sounds like you've got sorted, but if not i may know someone that may be able to help you out with a new seal.
    Ginge
    Mar 2010
    denmark
    5
    Re: S87 stal screw
    Please contact johnson controls denmark an ask for the repshop/tonny jørgensen
  1. Service manual for STAL Screw compressor
    By pfwousv in forum Industrial Compressors
    Last Post: 23-08-2011, 07:17 PM
  2. Stal vertical screw compressor
    By Kota.Kumar in forum Technical Discussions
    Last Post: 06-11-2010, 08:17 AM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. STAL SRM SCREW compressor
    By graeme ellis in forum Industrial Compressors
    Last Post: 15-03-2007, 02:01 AM
  5. Stal Screw Compressor R5-mkii 100kw
    By REFSOO in forum Trouble Shooting
    Last Post: 20-01-2007, 01:09 AM
