Results 1 to 9 of 9
    wanshah's Avatar
    wanshah Guest
    Dew Point Control
    hello refrigerant men, i am setting a new test rig for my Research & development. I am thinking to use dew point sensor to control spesific moisture contain (grain/Ib of dry air). May question is .. is there any lates or better sensor to control the dew point ?
    Thank you
    Nov 2010
    Germany
    120
    14
    Re: Dew Point Control
    could you be more clear what you would like to control, for which application etc. With the sensor you cannot control anything, it is just for measuring..Describe what you would like to achieve an i will try to help
    BR
    Oct 2003
    5,630
    34
    Quote Originally Posted by MilosBog View Post
    .. With the sensor you cannot control anything, it is just for measuring..
    Why not? We have applications running where we control Munter dryers with a dewpoint control to prevent moisture buildup on steel columns in a skating ring.
    Sep 2010
    Kazakhstan
    36
    Look michell.com
    11,025
    As Sserrviceman said, try here...
    http://www.michell.com/uk/category/d...ansmitters.htm
    Nov 2010
    Germany
    120
    14
    Sorry, but sensor needs to be connected to something. It gives the signal and the converter or actuator knows what to do with it..It is exactly what you have mentioned, with your dew point control for a skating rink
    Oct 2008
    mallorca, spain,
    75
    768
    yes milosbog , but I think he means a
    humidistat, sedgy,
    Nov 2010
    Germany
    120
    14
    But that is also a controller, not only a sensor.
    By telling this thing I wanted to be clear that some kind of controller or direct actuator should be used with sensor. I just wanted to make a clear difference between it and that was all.
    Nov 2010
    Germany
    120
    14
    And for what application do you exactly need this ?
  1. Carrier Transicold Container Problem
    By Shamel in forum Transport
    Last Post: 23-01-2012, 11:23 PM
  2. Replies: 2
    Last Post: 27-02-2010, 05:05 AM
  3. Lost Remote Control for Split System AC
    By kiamaian in forum Air Conditioning
    Last Post: 12-04-2009, 06:12 PM
  4. Control scenario
    By Mike Hopkins in forum Technical Discussions
    Last Post: 14-09-2007, 11:25 AM
  5. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
