Thread: Norfrost problem
07-12-2010, 11:59 AM #1
Norfrost problem
Hello
I have just moved house and our freezer was sent over in a van, we plugged it in and assumed it was still working. Checked yesterday and it had defrosted, checked the fuse and there was only a 5amp fuse in there (we think someone had changed the fuse between houses to pee us off).
I changed the fuse to a 13amp fuse and the light for boost comes on BUT the freezer isnt freezing at all.
would me plugging it in with a 5amp fuse has blown something.? or could it be something else.?
regards
07-12-2010, 08:04 PM #2
Re: Norfrost problem
5 amp woud be correct for the normal 5cu ft Norfrost, it's likely had a fault and blown that hence light only now points to a compresssor/electrics fault.
Could be damp on the relay causing short.
07-12-2010, 09:17 PM #3
Cables or wire damaged during move...
Its broke...
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
A strange problem
By MuhengineeR in forum Air ConditioningReplies: 14Last Post: 27-10-2010, 05:21 PM -
Fujitsu Multi problem
By BMS1 in forum Heat PumpsReplies: 15Last Post: 02-09-2010, 06:41 AM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Hot start problem on VRV REYQ14M7W1B
By cool#9 in forum Air ConditioningReplies: 9Last Post: 20-04-2007, 08:09 PM
