    Apr 2005
    48
    Hydrocarbon venting
    Hi all
    Not sure if this is just news to me but venting refrigerants is illegal, unless we are talking hydrocarbon 'natural refrigerants'
    Current practice in the UK (in line with Europe) is to vent up to 150g of HC refrigerant when servicing systems.
    This would apply to commercial cabinets that do not exceed 150g.
    The HC must be vented to outside a building, at least 2 m from the building where the air is moving to disperse the refrigerant safely, away from sources of ignition and where it will not drop into below ground areas.
    Lifes for learning.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Hydrocarbon venting
    Venting hydrocarbons is not illegal, up to now.
    Actually, PE foams are expanded with HC gases, mainly isobutane. After the expansion, HC is replaced with air in special curing warehouses.
    It is good practice, though,to properly avoid accumulation, as you mentioned.
    Apr 2005
    48
    Hi NoNickName
    Your absolutely right.
    Cyclopentane is another natural hydrocarbon gas used as a foam propellant.
    I know some manufacturers still use 134a in the commercial cabinet sector.
  1. Replies: 6
    Last Post: 08-11-2010, 01:56 AM
  2. Freeze Spray -- Venting R134a Illegal?
    By Z2TT in forum Chit Chat & Service Stories
    Last Post: 29-07-2010, 09:29 PM
  3. COMPARISON OF HYDROCARBON R-290 AND
    By shogun7 in forum Refrigerants
    Last Post: 12-01-2009, 07:30 PM
  4. Illegal venting of refrigerants
    By chataroets in forum Refrigerants
    Last Post: 22-01-2008, 07:02 PM
  5. Hydrocarbon refrigerants
    By mbeychok in forum Refrigerants
    Last Post: 01-09-2006, 10:03 PM
