    Amanindia's Avatar
    Amanindia Guest
    Smile Need All possible help on setting up 1000 MT CA strore.
    Hi All . I am new to this Line but have decided to venture into CA Store of approx 1000 mt capacity ( 125 x 8 or 150 x 6) primarily to be used for storage of Apples. I need to finalise the Refrigeration equipment and the design as a whole to operate the store where climate conditions vary from near 0 deg C in winters to 45-46 deg C in summers. I have a fair idea of the basic equipment such as N2 Generator, Co2 scrubber e.t.c required to control the parameters but have no clue as to which kind and what would be best for these conditions. As I am not an engineer i would appreciate Layman language. Thankyou all.
    Aug 2009
    New Zealand
    59
    2,554
    26
    Re: Need All possible help on setting up 1000 MT CA strore.
    This type of project needs to be done RIGHT.
    Contact this guy (no affiliation to me)
    Mike Odey
    Director
    Ph+64 4 939 2657Fax+64 4 939 2658Mob+6421 418 721
    mike@storetech.co.nz
    Amanindia's Avatar
    Amanindia Guest
    Thankyou so much. will do.
  1. TEV superheat setting and low temperatures
    By DaBit in forum Fundamentals
    Last Post: 01-03-2010, 02:11 AM
  2. Setting Daikin VRV indoor unit fan speed
    By mchild in forum Air Conditioning
    Last Post: 24-10-2009, 07:34 AM
  3. Manual Vi setting for Howden WRVi255
    By desaipt2003 in forum Industrial Compressors
    Last Post: 04-08-2009, 11:47 AM
  4. Cooling down the water in a 1000 liter container
    By Joep Hogenhout in forum Technical Discussions
    Last Post: 21-04-2009, 01:27 AM
  5. LP switch pressure setting for Pump Down of Chiller
    By venugopal in forum Technical Discussions
    Last Post: 12-11-2006, 07:18 PM
