    Feb 2010
    usa
    21
    Kobe/FES shaft seal
    I've just rebuilt a small FES Kobe. There was a spacer sandwiched between the shaft seal sleeve and the coupler. Some tell me this is important; others say it is unnecessary. Can I just use a split lock coller (like the small Frick's) to prevent the sleeve from sliding out; or am I missing something here.
    Apr 2008
    215
    Re: Kobe/FES shaft seal
    Hi Salamander
    Not familiar with your type of compressor or the spacer that you decribe.
    Sometimes sleeves are used to repair shafts that have been damaged/grooved by wear, overheating etc.
    Have you got rebuild instructions ?
    You need to check that you've got the correct ammount of compression of the shaft seal.
    Ginge
    Jun 2009
    Canada
    55
    82
    15
    I believe this spacer keeps the seal assembly firmly seated in the lip seal, so yes it would be important.
    C Ice
    Jul 2005
    61
    68
    CanadianIce is correct, it is important.
    It is there to keep the seal seated.
  1. Self sealing shaft seal.
    By Grizzly in forum NH3
    Last Post: 16-11-2010, 08:43 PM
  2. shaft seal failure
    By modvalve in forum Industrial Compressors
    Last Post: 01-04-2010, 06:02 PM
  3. Frick 193 shaft seal
    By NH3ISFORME in forum NH3
    Last Post: 14-03-2010, 09:35 PM
  4. Mechanical Shaft seal
    By amir.h in forum Technical Discussions
    Last Post: 23-12-2009, 02:52 PM
  5. Frick shaft seal leaking
    By Ian B in forum Industrial Compressors
    Last Post: 27-01-2009, 10:31 PM
